>Following some of the info I got on this site I made a set of thread chasing tools. I cut a 3/8x16 all thread in half and then welded them to some scrap steel. One was an old chisel, the other was an annealed file. Hopefully I will have time to test them out tomorrow.
I have another idea of how to make the tools that is so simple anyone will be able to do it. I hope it works. I'll post a photo if it actually works.
>John, rather than using all-thread someone I know makes them from dies from a tap and die set and then just brazes them onto some flat bar. He gets two sets from one die (cut into four) they seem to work well for him.
They look very nicely made. Will also be interested in seeing if your simplier way works. I have been very interested in threading lids and finials for boxes. The cost of the threading jigs have made them prohibitive up to this point.
Just curious, I think I recall you indicating in another "thread" that you had one if the Baxter jigs. If so, why all the effort to hand thread? Is it just the challenge or are there limitations to the jigs?
>Part of it is the challenge to hand chase. I've been fascinated by that process every since I first saw it. It's also very quick.
You have to set up the Baxter threader on your lathe or you need another lathe or a homemade device like I built to hold the threader. Then you have to remove the chuck and put it on the threader. You are also limited by the depth of the piece if you want to check the fit. Vic puts a pretty long threaded rod on so that you can crank it back and test fit the lid but sometimes it's not long enough. Of course his jig is also accurate enough that if are careful in your measurements the threads will always fit. To test fit larger pieces you have to screw the chuck off the threader and check the fit and put it back on, etc. It's a pain but doable.
My Baxter jig is limited in the size it will do. I can cut threads in pieces about 1 1/2 to 1/3/4 (I'm guessing I would have to measure to be sure). The new version has an extra dovetail on the bottom to let you do larger sizes. I'm going to put a sliding device on the router side of my homemade threader to accomplish the same thing.
With hand chasing you can just pick up the tools and start cutting, test fit whenever you want, and make any size you want. They are also way less than the cost of the Baxter jig (however I paid for my Baxter jig in sales in about 3 months. The downside, you are pretty limited in the woods you can use to make threads by hand.
Thanks for the detailed response. I kindof gathered that there may be a lot of setup associated with the jigs and I had heard of limitations of test fitting.
I think I recall seeing where someone made chasers out of hardened bolts. Is that the basis of the other method you have in mind?
>No mine will be made out of tool steel but it's the process of making them that if successful will be quite easy and not require any weldingl, accurate filing or any other skill beyond the casual woodturner. I'm buying the supplies today if I don't have to work through lunch and will give it a go tonight. It's one of those things that sounds easy in my mind but may or may not actually work. I don't see why it won't but I've been wrong before. One time I thought I was wrong but wasn't. :)
>I've been thinking about the possibilities of using threaded parts for attachments, such as feet or legs on a piece. I also look forward to your results.
>Heck Keith, for legs and feet, why not use a traditional tap and die? It will depend on wood of course, but blackwood, redheart, hard maple, etc., will work just fine with machine threads. Unless if you are talking about 2" diameter feet, then that's something completely different.
>Well I started on one tonight but got interrupted. It looks like it makes a thread but since I didn't have time to polish it and try it out I don't know how good the threads are.
I cut a slot in a nut that fits the steel I wanted to use. I put the steel in the slot and then clamped the nut in a vise which clamps the steel in place. Then I ran a tap the same thread as the nut down through the nut threading the steel.
Just looking, it might need to be sharpened because the teeth are somewhat rounded at the tip. This can be done with a triangular file if your careful. Before I do that I'm going to hone the top and try it out to see how it cuts.
I'll post photos after I get a chance to work on it some more. It will probably be Thursday or Friday.
>I think I remember some old adjustable thread boxes-kinda simlar to a bearing separator. They could be adusted to larger or smaller diameter rods within a range. That would get the external,might hard to match up with a internal thread however. People had many ways of doing threading.. Keep on experimenting John... pw.
