Another crazy idea
Another crazy idea
Another crazy idea
David Belser
>The picture quality isn't great but you get the idea. Because there are two full sets of rings you always end up with complementary bowls.
Re: Another crazy idea
David, your mind is a mystery to me! Awesome!
Molly Winton
Re: David, your mind is a mystery to me! Awesome!
David Belser
>Thanks Molly! Look forward to seeing you this weekend.
Steven Kubien
>This is really neat. I especially like the bottom left version. In the photo it looks like REALLY well done pyrography ala Al Stirt.
Fantastic.
Steve Kubien
Ajax, Ontario
I whish! *LINK*
David Belser
>I could do designs like Al Stirt! I've been meaning to take a class with him, I love his stuff.
I've posted a link to my facebook photo album with individual photos from the composite along with a few more comments.
Better Photos
Re: I whish!
bowlman
>Can you give a better explanation of how you cut the disk into rings that fit so nicely together?
Love the optical play
keith zimmerman, Normal IL
>Visually, these pieces are astounding. I really like how you use the positive and negative spaces.
keithz
Me too! How'd you do dat?
Re: I whish!
David Belser
>As you may imagine, the process is a bit complicated. It's not so much difficult it's just that there is plenty of opportunity to screw up along the way. The farther along you get in time invested the more painful a screw up is.
Basically, I cut out (jigsaw) two full sets of rings with plenty of margin to turn away. Then the insides are turned by holding the rings in a cole jaw type chuck. At that point you start with the smallest ring and work out, assembling as you go. Turning the out side to match the inside (that you already turned) of the next bigger ring. Each time you offset the center.
It's tricky because you are working two sets at once and have to keep mounting and remounting. I used to special chuck setups for this.
Once you have the nested ring "blanks" you turn the identical dish shapes and paint and carve.
I guess I'll need to do a demo for this :)
Keith Tompkins
Re: I whish!
Keith Tompkins
>HI David, I think you need to register for the Showcase exhibit, but the Totally Turning show is a separate affair. I don't think you need to register for that one. You're on to something good!!!!
