200+ woodworking book reviews
Another crazy idea
Another crazy idea
Another crazy idea
David Belser
>This project is made form two matched sets of rings. I got the idea from a book of optical illusion patterns. I've been thinking about doing this for quite awhile, I finally managed to take two weeks in a row off from work and this has taken me most of the first week.
I made two identical ring sets from cherry, the inside/outside diameters are offset slightly so each ring varies in width as you go around it. I then painted (one black one white) and carved v-grooves (one with the grain one across). Finally the rings are re-assembled in contrasting order.
I discovered that it is a lot of fun to just play around with rings, arranging them in different ways. So I decided to leave them unglued int the final form. I turned the sides and bottom vertical and flat so that the basic form is a cylinder with a sphere turned in the top.
I'll post a composite of different arrangements next.
Re: Another crazy idea
David Belser
>It's been so long since I've posted to WC that I forgot if I have to ask for comments/critique..... Both are welcome.
Al Neighbors
>You've lost me. I don't get the picture, but then I rarely do until it's drilled into me. I don't see the cylinder, or the sphere. Can you elaborate some more?
Thanks,
Keith Tompkins
Keith Tompkins
>Hey David, This is awesome!! I wouldn't have expected less!!What a great wall hanging this would make!! Bringing this to totally turning?
Al Neighbors
>I guess I must be blind. :)
>REally cool. I bought a book on optical illusions several years ago but haven't taken the initiative to try anything yet. Thanks for posting.
David Belser
>It's not that hard! The illusion is a little more obvious on the mostly white one in this picture. Imagine the white as raised circular rings with the black as an abyss in between.
I was speaking just of the form when I mentioned the cylinder and sphere. Each dish is just a flat puck of a cylinder, 9 inch dia and about 1" thick on the rim. Into that I turned a spherical hollow, the dish part - that's all. Had to make them identical so I could swap the rings around.
David Belser
>Yeah, I'll bring it to Totally Turning. I guess I'll see you there this weekend?
I messed up on the instant gallery for TT, didn't realize that I needed to "pre-register" so I missed the dead line. Not sure if this was done prior to the deadline anyway!
The rings are just a little too tight to leave it out for the general public to play with. I guess it will be shown on request.
Ray Carson, New Jersey
>I'm dizzy in a cool sort of way. Neato.
Ray
