>I've got a can of "Howards Restor-A-Finish". It's sold in a lot of antique stores for removing scratches in an existing finish.
I've used it on occasion and find that it leaves a nice "fresh" look to an old finish. I just used it again today.
But now I'm curious! What is is really? It says it contains "petroleum distillates and toluene". That's it. I'd like to know more about where it falls in the spectrum of varnishes and oil finishes (probably "none of the above") and what all uses it may have. Also, what should it not be used for? (It says not to use it under poly.)
What I've used is basically a mixture of sovlents with some tint. It works by disolving the very surface of the old finish and redestributes the slurry with the additional tint. For general "pick-me-up" for mildly damaged surfaces it works great. It is not a substitute for re-finishing if that is your aim.
>What's in the can is a mixture of 3% to 5% each of Xylene, Toluene, and Benzine. The other 85% is listed as a "petroleum distillate" which means a more highly refined form of Mineral Spirits that is known as Stoddards Solution. These solvents are available in most well stocked paint stores, and you will find the Stoddards Solution being sold as "Unscented Mineral Spirits"
This is a weak mixture of solvents that will (as John has already said) soften the surface of old oil varnish and shellac finishes so they can be spread around again in an attempt to cover the worn spots and fill in the cracks before the solvents evaporate. Used as intended, it works on cured oil varnishes and shellac.
How well it works is a personal opinion. Mine is that it doesn't work very well. It doesn't rejuvenate or add anything to an old finish because it has no oils or resins to add to them. Old finishes that are already worn thin with age are spread around so there is even less finish on the wood than before, and a lot of it is removed with the rag used for the spreading around. The old finishes may look good after they have been repaired with this solution, and color can be added with the solution. The problem is there isn't enough finish left to have any durability and it soon ages and wears back to what it was, and old finish that needs to be stripped and refinished.
Antique dealers use it because it is a quick cosmetic lift that makes an old finish look a little better for as long as it is on display and not used; and they can honestly say that the finish is original. You may want to use it for that same reason, but don't expect it to take the place of refinishing the wood.
>... type finishes with stains to touch up scratches in antique and other vintage furniture for many years. I have done small custom repairs for several galleries in the area, as well as the scratch and dent accidents that happen in every home, especially those with "active" kids. Having grown up in a family that collected (and often refinished) antique furniture, it is a way of life, and stuff happens!
>Thanks for the info. Just out of curiosity, how does the "wipe on, wipe off" Danish oil fill scratches? Aren't there potential compatibility problems with putting oil over unknown "varnishes" that could be poly or lacquer, or...? ...Gary
>scratches but simply blends them into the surrounding surfaces with a good color stain match. The small amount of oil has never been a compatibility problem with other often unknown finishes.
