Have a question? Ask Woody!
Jet mini lathe bed extension
paul waddle
>When attaching a bed extension to the lathe,is a middle support necessary? I got a special from Amazon,just the extension . I used the original back legs and made a cross pc and bolted it to the original cross pc to span the new length. My question is: should I bolt an additional support to the place where the original legs were? If so,should this support extend to the floor or just to the cross pc. I've been using using lathe with no additional mid support,the extension bolted on very good, and the tailstock slides smoothly over the joint between the two beds.. pw
Re: Jet mini lathe bed extension
Russ Fairfield
>My advice is, if you think it looks like it needs a mid-span support, put one in. It may not need it, but without it, you will always wonder. I would use a length of 4x4 and two opposing wedges under the lathe bed. You might want to use the cross member of the stand, if you have one, for the bottom of the 4x4. If you wnet to the floor, you would have to reinstall it every time the lathe moved.
I have a Oneway 1018 with a cantilevered bed extension. I cut a length of 4x4 that I wedge under the end, not because it needs it, but because it makes me feel better.
Others will have other suggestions.
paul waddle
>Thanks Russ,I think I will put a brace under the bed to the cross pc. Like you said,it just looks stronger.. pw
