Re: If you really want meaningful advice,
Bill Howatt
>That makes a big difference since this forum tends to deal primarily with lathe issues by default.
Green-Green
White-White
Black from male plug on cord to C
Black to female receptacle on cord to NO
(If you put the black wire on NC, then the dremel will run until you press the switch, and you don't want that.)
Be sure you carefully connect the wires and use proper wire nuts to reconnect any wires you have cut such as the white and possibly the green. If you have a ground screw you may find it better to put a short piece of #14 wire (a pigtail) under the ground screw if there is one and then connect the two greens from the cut cord to it and bond them with a wire nut. The alternative is to twist the 2 greens together and put under the screw but sometimes this makes too big of a wire for good mounting under the screw.
As always, when dealing with a 120V circuit you want to put the switch in the hot lead which is the black.
The green safetly ground must never be switched and must always be connected together and to the ground terminal of any piece of equipment having a ground terminal. Total plastic "devices" may or may not have a ground connection but a metal one almost always will.
The neutral (white wire) is usually not switched.
I only use a foot switch on my drill press where I find it very convenient because it frees up a hand and I could see this benefit in using a dremel. I personally feel that they reduce the level of safety and would not use them on any other device because I don't see any real benefit. Be careful.
Bill
