The PM headstock slides again!
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I got it unstuck -- thanks to you all. Big car jack applied pressure in tension mode. Shear didn't work. Please see my last post in the original thread. And thanks again! A wonderful group of people here! I can assure you that I'm keeping CA glue off the lathe bed in the future!
Re: The PM headstock slides again!
Dave Andeson (PacNW)
>Congratulations, Ikeep my lathe bed well waxed to keep glue, fnish and other assorted concotions from sticking to it.
>Yes, but what happened was that the thin CA glue wicked under the headstock and created a bond under there. So even if the bed was well waxed, I think the thin glue(it's like water) would have run under the headstock.
>Now that I've thought about what you just wrote, I see that your point is that if the bed was well waxed, the glue just wouldn't have stuck. I do oil the bed a lot, and that obviously didn't keep things from gluing together. I'll use wax in the future. (By the way, would you believe that no less an authority than David Ellsworth advocates going completely in the other direction and causing the lathe bed to rust so that the head stock, tail stock, and banjo will NOT slide easily and therefore set up a more stable hold.)
>I think the rusting bed idea came about on less expensive lathes. Most of the newer good lathes don't have a problem with tailstock creep. The proper solution is to make a tailstock clamping block that is larger. many lathes have a block that has very little surface area so the block tends to slip which lets the tailstock slip. You could rust the underside of the bed which might let the tailstock lock hold better.
How does David get his Robust to rust?
Jerry Hall
>He has a couple American Beauties now, so maybe he has had to develop a technique to corrode the stainless steel ways. Maybe you can get a special order from Brent in iron for only a little more.
