>I turned a spurtle from walnut for use in cooking. Was it a mistake to use walnut? It occurs to me that walnut shavings are a problem for some animals, for example.
------WebKitFormBoundaryqLjotTOkmgc+twQD
Re: Is walnut safe for a spurtle?------WebKitFormBound
robo hippy
>The worst thing about it is that it can add flavor to whatever you are stirring, and it will diminish over time. Using it with hot liquids will add some flavor. Like with the salad bowls and plates, I tell people that it is a strongly scented wood and drives some people nuts, and other people love it. For me, I think it could add to a salad, but with ice cream, never. If you are walnut wood sensitive, which is not the same as being allergic to the nut meat, eating the wood would probably cause problems. Eating out of walnut bowl PROBABLY would not cause problems.
robo hippy
Al Neighbors
>Her Majesty and I use Walnut Bowls, and spreaders, etc., made from Walnut, because it's beautiful wood. We've never had any problems. I think a Spurtle from Walnut would be fine.
>I don't think you will extract enough toxic material from walnut for it to make a difference.
I wouldn't use walnut because it has some open pores. I prefer to use a close grained wood such as maple or possibly cherry. I remember the first walnut rolling pin that I made - and how it looked after I used it.
>I have made myrtle spurtles, but I didn't think you Californians knew that myrtle is really California Bay Laurel and not really myrtle at all. Must be marketing.
