Re: What's the preferred glue
Jorge Castaneda~Downeast Maine
>Carole,
I think they are two incompatible materials for bonding, PVC needs a solvent and is non porous, so unless you abrade or partially drill holes in the PVC for the epoxy to get in, it is not going to work.
John's solution is a better way. I have bonded those two in construction using 3M's 5200 rubber, an industrial adhesive, takes about a week to set, and then is there for good, using this you could make a grove in the MD to fit the PVC and then bed it with the 5200.
Jorge
