>Jeff put my vacuum system together today and it works great! It will pull much more than I need (28") and the little Picolino VTE 3 pump is quiet as a mouse. I bought one chuck when I bought the HoldFast but I like the one I made with MDF, PVC pipe and a Foamie better. The seal is thicker on the store bought one and allows it to flex a bit.
A huge thanks to Jeff Willaford who put it together and to Pete Kekel who donated the pump!
>I think if you look around your shop, you may find them. You said in an email that you found them sitting in your shop after you thought you had sent them, then you went off to France or somewhere and probably forgot when you got back. That's ok...we are all getting to that age. ;) Maybe someone else can use it. Thanks for the thought. :)
>Congrats Carole-you will enjoy this device very much. I finally managed to cobble together a simple setup myself and boy is it nice to work with. I made all my chucks from MDF soaked in water borne poly direct threaded for the spindle and PVC pipe. I have 2" and 4" now and have a piece of 3" PVC to make more if I want to.
>I'll take a picture tomorrow if I have time. It's actually pretty simple once I saw it all done. Jeff had to wire my pump, fashion a connection cover, which was missing, install some fuses and a switch. That cover was the time consuming part. You wouldn't have to do that with a pump you bought. The other connections are a brass cross fitting with a ball valve, a vac gauge and two quick connect fittings for the hose from the pump and the hose from the vacuum adapter. The cross was 3/8" but we stepped one arm down to use the 3/16"ID hose that came with the HoldFast because it was more flexible than the 3/8" hose.
