>Well after a lot of looking at web sights and reading I have ordered all,I hope, the stuff to build a vacuum system. I have less than $200 tied up. I am sure I will need a few other pieces but I live close to two box stores.
Thanks to all that helped me especially Jeff Williford and Sam McGarrity who called me to give all the information I could think to ask far.I new I could count on the Wood Central pack to help out.
>Jeff and I should have mine hooked up tomorrow afternoon. He picked up the rest of the things we needed when he was back in civilization (across the Bay) this weekend. When he gets his pump, we will work on his. I have been putting a sealing finish on some MDF faceplates. Going to go get some PVC pipe fittings tomorrow. I have one store-bought drum chuck, but it's only 3 1/2" and I wanted a couple of larger ones.
>Carole go to McMaster-car and check out some stuff called ultra-high molecular weight polyethylene(UHMW)It can be turnerd like wood and can be threaded too. I have used it to make centering cones for my live center. I have a piece that is 5:"D X 3" H. I am going to tap some threads in the back and put a face plate on. The drill a howl through the bottom. A little fun foam and I think it will work. There should be no air leake.
It can be taped with the Beall spindle tap and forgo the face plate.
>Wish I had thought about that stuff when I placed my order with McMaster Carr. :(( I already have a Beal tap for my spindle but I don't have an over-abundance of faceplates. BTW...McMaster (and Packards) got my stuff to me in two days!
>I used hard maple and the Beall Tap to make my chucks. Just make sure you face off the maple really flat. For my Jet 1642, I first drilled a 1 1/4" hole 1/4" inch deep and then drilled with the 1 1/8" bit all the way through the maple and tapped all the way through. Mounted the maple with the the 1/4" recess toward the tailstock and lightly trued faced off that side. Turn the blank around and fully seat and then do the rest of the turning and mounting of the PVC pipe. The hard maple works great and I do not get any leaks.
