Veritas - Innovation in Tools
When to replace grinding wheels
Wayne K
Wayne K
>I am using the Wolverine with the Varigrind to sharpen my bowl gouges.
I was getting very consistent results each and every time.
I now notice my gouges are not being sharpened all the way around on the swept back portion. I haven't changed any of my settings and use a stop block to set the gouge in the varigrind,
I have noticed my once 8 inch 120 grit wheel is now 7 inches.
Is it time to replace my wheel to continue using my current settings?
Thanks,
Wayne Kuhn
Columbia, MD
Re: When to replace grinding wheels
Doug Thompson near Cleveland
>Something might have moved a hair to change the setting... it doesn't take much. Keep using the wheels until they get close to 6 inches or before if the grind isn't right for your turning style.
Carole Valentine
>As your wheel wears, you will need to make some adjustments. As it wears and gets smaller, unless the arm of the jig is moved in to compensate, the gouge is going to be contacting the wheel at a lower point. (If it should happen to get below the centerline of your wheel, you may have a BIG BANG, a ruined tool, a ruined wheel and possibly a ruined YOU!)
PS:
Carole Valentine
>When you move the arm in, you usually have to readjust the varigrind to get back to the same grind on the wings you had before.
Your right Carol...
>I was thinking the block was like John Lucas made to set the V arm. Wayne, is the stop block controling the distance on the V arm slide or the distance from the V arm to the wheel?
Jim Shaver - Oakville, Ont
>Well if it is 7 inches now you will also have a different hollow geometry, the radius of the wheel has changed and so will your results on the tool, moving the jig in closer will help but you will have to adjust the Vari jig to compensate for the radius change too,
You've done those wheel a long while to get to 7 inches.
Take care,
Jim
Wayne K
Re: Your right Carol...
Wayne K
>The stop block is to set the distance the gouge extends from the varigrind. I set the v-arm by using the existing angle on the gouge, the black marker method without the black marker.
>I use my wheels until they are quite small. I think the last one was 5" on an 8" grinder. I don't recommend going that small. I use a jig to set the distance from my V arm to the wheel. This keeps all the angles the same. The only thing that changes is the amount of concave on the bevel. I have found this to be minimal and hasn't caused any problems. As mentioned above don't every let the tool grind at or below the center of the wheel.
