>I am going to make some pens for the people that work with my wife at the hospital. Because of what they do, they often have only 1 hand free to write so twist pens are a hassle. I have turned one click pen and it was from Woodcraft and I found the quality lacking (i.e. the clicking mechanism took several clicks to work and the writing from the pen was not good). So here's my question. Do you know a source for good quality click pen kits that possibly give discounts for quantity orders since I am looking for approximately 30 of them. I will check out your answers tomorrow. Thanks for your help!
>I have made both the Americana and the Wall Street version of the click pens... the Wall Street (called a Sierra by other companies) is better than the regular click pen you just made..
I've built about 50 of these Sierra kits and I really like them. Every one has worked well. Like you, I had problems with the standard kit from Woodcraft. I've gotten all of mine from Berea, no complaints at all with the service there.
>I like the Power Pen, Click Pen from PSI. The Power Pencil has a lead(2mm)that is about the same size as a regular pencil, with the sharpener in the cap. 8mm tubes.
And the click mechanism is better than all the others I've tried.
It uses a Parker refill. PKPOWPEN and PKPOWPCL. Link below.
>I must really like the Sierra pens since I've built more than 50 of them. The Sierra click kit seems to be the most robust of the genre.
The click kits end up about 1/4 inch longer than the twist version. The kit includs an ink cartridge extender to make it fit the kit dimensions. That adaptation makes the finished kit seem too top heavy for me to carry in a shirt pocket.
I've made a few modified pens with a shorter tube section that eliminates the need for the adapter and provides a better proportioned pen that's the same length as the twist version. The tube length of the shorter pen should be cut to 1.882 inches. This short Sierra click design came from some of the senior folks on the pen turning site. I carry one of them in my shirt pocket.
>If I remember correctly, the longer length of the Sierra Click from Berea allows the user to use it as a roller ball using the Uni-Ball refill The extender used on the Parker style ballpoint refill is removed if the pen is used as the roller ball.
