A55 Smoothing Plane
Water spots
Water spots
Water spots
r thomas
>I was at a Festival this weekend, it rained, my tent sides flapped and sprayed my bowls with water. I wiped them out and was able to continue selling the natural wood bowls. The ones I dyed with water-based aniline dye that are finished with a lacquer sanding sealer and the three buffing compounds, rouge, white diamond and carnuba all kept their water spots. I thought I could re-buff them starting with the rouge - it didn't work on the water spots. I guess I'm going to have to sand them down completely, re-dye, and re-finish. Any suggestions? I have started trying acrylic on some of my pieces, none of the dyed ones spotted. Is that what I am going to have to use on the dyed items?
Thanks
Re: Water spots
Re: Water spots
Dick Coers
>Lacquer sanding sealer isn't a very good finish by itself, and the wax doesn't add much except sheen. The sanding sealer is pretty soft. Before you strip the finish, I would try removing the wax with mineral spirits, then spraying the finish with just lacquer thinner. I think the water is in the sanding sealer and the thinner may melt that and let the water out.
Re: Water spots
Re: Water spots
Doug Turner
>Furniture re finishers use a small amount of denatured alcohol to remove the water from lacquer finishes that contain water spots. You might want to try some on a q tip cotton swab before you resort to more aggressive methods.
Re: Water spots
Re: Water spots
Scott in Socal
>Carnuba is terrible with water - I've stopped using it as the third step in buffing and now use Renaissance wax instead if I want a wax topcoat. Carnuba water spots instantly, and the spots are hard to get out. I've had luck with a good hard/hot wax buffing if they were light spots, or with stripping the wax with mineral spirits/naptha and re-buffing. The stripping process might require some very light fine grit sanding afterward if it raises the grain. If the spots are in the lacuer sealer coat, I'm not sure what to do about them.
Re: Water spots
Re: Water spots
r thomas
>Thanks for all the info. I will give them a try.
