>I'm having fun learning thread chasing. Wood (at least hard wood) is easier than PVC. Pvc cuts cleaner of course and doesn't have any grain running in odd directions but it cuts slow. I was able to cut the threads in wood with much less effort. Using Osage I'm getting some tearout on the top of the threads. I put some wax on and made a few more passes and got cleaner threads. Hopefully I will have some ebony to try. I do have some boxwood but I'm saving it for a special project. I may try some other woods that have laying around.
I'm going to try and build some threading tools tomorrow. It shouldn't be to hard I'm good with a file. I would like to try 10 or 12TPI. I've been working with 20 so far.
>Making threading tools would seem like a great project! Can you just make them like a thread guage,or do the threads need to have a spiral? That ebony is really expensive,hope you succeed. Keep us updated.pw
>Paul I've been using Johnson's paste wax. It works fabulous for stopping tearout when cutting wood with standard lathe tools.
My 20tpi tools do have a slant to them. They are quite thick. It seems like an article I read many yeas ago suggested making them with a slant so that's what I'm going to try. I'm headed to the shop to see if I have the proper stock. If not I'll head to Lowes and buy the cheapest chisel I can find and modify it. I may have an old planer blade but I can't remember if it's thick enough. Mark StLeger's thread chaser doesn't look that thick but I didn't ask him how thick it is.
I also use it on the beds of the lathes and it works better than anything else I have experimented with to prevent rust especially when turning green wood.
My Sorby threaders are 1/4" thick. There is no slant when they are new. Picture a 1/4" thick scraper with square end but with the teeth cut into it (for the outside threader).
In sharpening it, the top gets ground down and takes on a slant (angle). I find it easier to turn tool upside down and touch what would be the top flat to the grinding wheel lightly and quickly, don't need to grind away but tiny bit.
>Can you say what is different about this wax? Ingredience etc?
Possible it doesn't state on can but I've had good luck with the furniture wax from Australia in the yellow can, cannot remember the name right now. It is soft and I like it for end grain work as it is soft I can pack it into the tear out, sort of like packing a wheel bearing, and grain will cut much better. Also use that same method for the first sanding of the end grain. After that point it's smooth enough that wax not needed for the fine grit sanding.
Several years ago before I obtained my first thread chasers, I made a chaser by clamping the metal between two pieces of wood and drilling through at the end of the metal and then running through a tap with the size threads I wanted. At that time, it didn't work. Later after I had learned to chase threads, I tried it again and magically it worked.
So, I would recommend that you clamp the outside chaser and the inside chaser steel at 90 degrees to one another, drill a hole and tap it, thus creating both inside and outside threaders at the same time. The inside threader will require some grinding to shape, but it should work.
Finally, you can make both chasers at one time using a bolt or tap. Grind away one half of the diameter of the threaded portion and you have both an inside and outside chaser. Bruce Campbell in Canada introduced me to this technique and it does work quite well. It is very easy for the inside threads, but required some pressure when cutting the outside threads. Both chaser movements are done parallel to the rotating wood.
>My friend in Australia makes thread chasers exactly like Fred Holder stated. I have one, and it's made from a hardened bolt, and works like a charm. Left side of it is for the inside threads, right side for the male. If you like, I can find out if he's still making them. Postage from Australia is a bear, but it's well worth it.
>Fred I assumed you meant clamp the two pieces of steel 180 degrees apart instead of 90. I tried that with wood on both sides. I drilled through the center and then tried to tap the threads. I could not get the tap to follow a line through the steel. It kept wanting to fight it's way into the wood so I finally gave up on that. I'll try grinding the bolt.
