ring box thread chasing revisited
paul waddle
>I use 16 tpi and 14tpi for my ring boxes and .070 double depth of threads(.035 depth infeed). Bonnie Klein uses approximately the same. I came to this dimension experimentally and out of necessity. My threader gizmo mangles the thread crests if I feed deeper than .035.If I keep it under .034-.035, use wax lubircant,most walnuts and similar woods,thread satisfactorily. My recipe is: to either make the male portion to be threaded,+.070 larger dia than the female hole,or the female hole dia -.070 smaller than the male portion,depending on which you start with. The main point,make and measure this offset BEFORE you start theading-it was extremely inaccurate for me to measure the difference when one or the other pc was threaded.
Fred Holder formula,center guages& charts give much deeper measurements(ex- 16 tpi .081,14tpi .093) etc,but with a little sanding,my threads mate very well. I'm not knowledgeable enough to explain why this happens,but it does for me.. Try it, and see what you think.pw
