A little more help...
Marc Phillips
>... please.
I like doing natural edged bowls, but one part of the process I really struggle with is hollowing the inside area right next to the rim near the bark...
I *think* I need to almost finish the rim area before I go on to the before hollowing... right now I hollow the bowl equally... meaning the rim area isn't completely cut until the bowl is almost hollow...
Should I work on the inside edge more before continuing to hollow so the edge has some support?.... I just blew up a cedar bowl when I tried to clean up the inside next to the rim....
Re: A little more help...
>In short, yes. I turn about an inch deep all over and then I thickness the rim. Then I go another inch deep and then make a final pass to thickness this section of the rim and then shear scrape if necessary to blend the two areas. If it's a big bowl and I'm going really thin I will continue in this manner. If the wood was very green this outer lip can often move so you can't go back and clean it up later without either blowing it up or thinning 2 sides thinner than the other two.
For smaller bowls that aren't that thin I usually turn the whole thing very close to the final thickness and then make one final pass over the whole thing to take it down to final thickness and get a smooth shaped bowl.
If you need to go back and smooth out the upper inch I use a shear scrape with the bowl gouge flute facing the wood. I put my left hand on the outside to stabilize the bowl and then gently shear scrape until I've cleaned up this area.
charlie belden
>I haven't gotten to natural edge bowls yet, but a lot of turners in our club do natural edge - some do only natural edge bowls.
Here are some of their tips.
1. Tool should be SHARP - VERY SHARP
2. Start cuts at the bark and proceed away
from it, never the other way around.
You want as much support for the bark
as possible.
3. Get the outside shape FIRST so you've got
plenty of meat behind the bark
4. When working the inside - do it in steps
from the bark inward- light cuts as you get
close. Finish each "step" as much as
possible before going deeper to prevent
thin walls from flexing.
Careful CA glue application on the bark - but not on the wood - seems to be helpful if there's a potential for the bark breaking off.
Marc Phillips
>Ahh... OK... I am going to try this on the bowl that is on the lathe right now...
I was hollowing from the middle out, and trying to get the inside shape to match the outside shape as I went... basically making the whole bowl hollow from the center out....
I will report back on the red cedar bowl that is out there now...
Thanks John... very helpful indeed...
Marc Phillips
>Thanks Charlie...
"Finish each "step" as much as possible before going deeper to prevent
thin walls from flexing"
I do all of the steps you outlined except that one... I was doing just the opposite actually...
Thanks for the help... I appreciate it.
bill Crommett
>Mark: I keep a chunk of black Willow around just to cannibalize a piece of bark when I knock a small chunk off.. Willow bark will match most others with a little bit of posturing, and can be sanded down to the size you need to fill a spot.
>I know what you mean by hollowing from the middle out. I used to do that. You make a small bowl that mimics the shape of the piece and each pass enlarges this shape. You get lots of chatter by the end especially on thin pieces or flexible wood.
Try cutting from the center out to within a few millimeters of the final size. Go down about an inch doing this and then come back and clean up the first outer inch. You'll be surprised how much easier it is to control the chatter. Don't rule out using your hand on the outside to steady it. Just don't do that on a natural edge piece that has an interrupted cut or your fingers won't like you any more.
