200+ woodworking book reviews
Andromeda
Andromeda
Keith Tompkins
Andromeda
Keith Tompkins
>A while back, I asked on WC for sources of Holly. This is one of the pieces I needed the wood for. (Thanks,all) This is a piece that continues my linenfold series; in this case, applying the theme to a bowl form. The bowl is applied metal leaf, the finish is lacquer. This is a square suspended bowl, which has been sawed and carved. Comments and critique welcome, thanks for looking.
Re: Andromeda
Bob Moffett
Re: Andromeda
Bob Moffett
>That is beautiful. I like the way the texture swirls and the gold leaf on the inside of the bowl. A very sensual piece!
Re: Andromeda
Metal leaf?
Steven Kubien
>Keith, this is absolutely wonderful. The bowl has great lift, almost suspended in this camera angle. I notice you said "metal leaf" and not "gold leaf". I assume they are two different things and I love the effect of what you used. The swirls in the leaf add richness and depth that, I think, gold leaf lacks. Where does one get metal leaf?
Great stuff!
Steve Kubien
Re: Andromeda
Keith Tompkins
Re: Andromeda
Keith Tompkins
>Thanks Bob and Steve. The bowl section is indeed suspended above the surface, only the very wingtips touch the ground. Metal leaf is made up of an alloy of brass and copper, I believe. It has been heated to create the colors in the metal. I chose the metal because the swirls added to the effect. I used black gesso to create a smooth base, then red oxide primer over it. The metal shows every minor defect, such as brush marks, so I used a fine sponge to apply the size (glue).
Re: Andromeda
Steven Antonucci
Ok, now I can throw away that sketch!
steve antonucci
>M31 is one of the most awesome sights in the night sky. I had a sketch in my notebook to do something based upon it, but now I'll just be accused of copying you!
Please bring it to Totally Turning, even if it isn't going into the IG. It looks amazing.
Steve
Re: Andromeda
Re: Andromeda
Mike Brazeau
>Awesome piece Keith!
Re: Andromeda
Keith Tompkins
Re: Ok, now I can throw away that sketch!
Keith Tompkins
>Hi Steve, Thanks. I cannot bring it, it's on the way to L.A. for an exhibit. I find it amazing how often spiral forms show up in nature, even the galaxies display the same form. If we gaze skyward, and aren't awe inspired, perhaps we should check our pulse. That happens to me too; I'll see a piece online, then have to tear a page out of my book. Hi Mike...thanks, I appreciate it!
Re: Andromeda
A friend of mine has been using galaxies as design inspiration for some time for his pottery. Here is a picture I took of some pieces coming out of the kiln. You can't see the final colors (these are raku) but you can make out some of the design. The largest pot is probably 48" or so high.
Your wooden piece looks great. It would be nice to see a bigger picture.
Re: Andromeda
Re: Andromeda
mfoster------WebKitFormBoundarylEl+W1ObyRf+RBoi---
>Another great piece Keith. Love the concept and the execution. Who would have thought of morphing a square suspended bowl into this? After thinking about it, it makes sense. Why waste the wood on a round form if the square gives enough wood to complete the piece.
The leafing is really nice and complements the piece well (A little bigger picture would be nice). Learning to do leaf is on my short list of things to do.
Really nice piece. Too bad we won't be able to see it at Totally Turning.
Mike
Re: Andromeda
Keith Tompkins
Re: Andromeda
Keith Tompkins
>Thank you, my friend! See you in Saratoga! Can't wait to see what you bring!
Re: Andromeda
Keith Tompkins
Keith Tompkins
>Wow John, these are beautiful!! Thanks for posting this!!
Re: Andromeda
Keith Tompkins
Re: Metal leaf?
Keith Tompkins
>Oh, Steve, any craft or art store should carry it.
Re: Andromeda
Re: Andromeda
charlie belden
>The folds introduce a subtle incongruity/paradox to the piece. Fabric is flexible so it can be folded. But if it can be folded - how can it be holding the central part of the piece up off the surface it's sitting on? The conscous mind might not register this, but the subcocsious will play with it, trying to resolve things.
Very nice piece and an excellent guilding of the lily.
A larger photo sure would be appreciated!
Re: Andromeda
Re: Ok, now I can throw away that sketch! *LINK*
>I'll tell him what you said! The website in the link below has some pictures and video if you'd like to see some finished pots, the studio, etc.
(Last I checked the web site WILL NOT work with IE, but works fine with Firefox and Mac browsers.)
It's awesome to be there in person when the pots come out of the kiln, experience the size, feel the heat. For the raku process, he has devised a huge counterbalanced stainless drum containing the combustibles which is quickly lowered over the cart and sealed at the floor. Patience helps - you can't see the results until the pieces cool overnight. He will sometimes refire a pot 5 or 6 times until he is happy with the colors and texture.
He makes perhaps some of the largest (if not the largest) raku-fired pieces in the world. I have one about 3' tall in my music room for inspiration while playing the piano. :)
Paul is an amazing wood turner as well.
http://www.paulmenchhofer.com/
Re: Andromeda
Cool. Thanks.
Steven Kubien
Re: Andromeda
Keith Tompkins
Re: Andromeda
Keith Tompkins
>Thanks Charlie. We all know wood is not flexible, and not easily worked, so to see a piece of wood that seems fluid may cause a bit of consternation on the viewer's part....it may cause them to pause and think for a moment. Also, seemingly in constant motion while sitting absolutely still....that's what I attemt to do in my work.
Re: Andromeda
Re: Andromeda
>Keith Wonderful take on the floating bowl concept. It works well with your linen fold carving and fits the Andromeda concept. I love it.
Re: Andromeda
Keith Tompkins
Re: Andromeda
Keith Tompkins
>HI John. Thanks very much. I'm pretty excited about the direction these pieces are heading. I've got a couple more in the works.
Re: Andromeda
Keith Tompkins
Keith Tompkins
>Hey John, How did you post such a large image?? Thanks. I enjoy nearly all craft forms, I encourage students to study them, especially ceramics. Check out the work of Jennifer McCurdy, a google search should work. Yes, tell your friend I think his work is awesome!
Re: Andromeda
That particular image is hosted on an external server (in this case, photobucket) and posted by embedding a line of html code in the message. This is the method to use if you want to put more than one photo in a message as well. (instructions are in the FAQs here)
BTW, in general I don't like this method since if the image or the external server goes away for some reason, the photo is lost in the message. I've encountered several messages in the archives here with this problem. I used this method in that message since I was working from my laptop and didn't have the original photo handy. (I guess I could have downloaded the image and posted conventionally, but I didn't think of that at the time.)
But as for image size, you can actually post very large images the normal way if you compress them enough to keep under 80K. Keeping in mind that JPGs with less detail (i.e., smooth backgrounds) can be compressed far more without losing as much quality as a "busy" photo. As a test once, I posted a 2560x1920 image - not too practical for viewing, of course, and it shows every tiny imperfection! The upload size was 78.7k:
