BEHOLD! The ring master... *LINK*
Mike Jones, Redding, CA
>Who needs a lathe?
http://www.toolcenter.com/ring_master.html
>Who needs a lathe?
And what a bargain price!!
Richard Jones
>I didn't know Ron Popeil was still around.........
R
Re: BEHOLD! The ring master...
Mike Stafford
>What I like is the first statement in the write up...
"4 EASY STEPS to making beautiful and unique wood shaped bowls, canisters vases and jars."
I have enough problems making bowl shaped bowls so making unique wood shaped bowls would be quite an improvement for me.
Uhh, I don't think I have any place in my shop for this woodturning wonder.
For $730, I'd rather have a lathe.
>I know you can get a variable speed Jet mini for under that. You may even get the new small Delta for about that price.
Behold! A parting tool will make rings too...:-)
steve antonucci
WOW!
GalenV in Iowa
>Now as a novice turner in just four easy to follow steps I can produce a segmented turning just like I see in the woodworking magazines!
Yah Right!
Galen
bowlman
>ugh!
paul waddle
>Years ago,this tool was popular-cost about 125$. I suppose tools too,go in cycles. pw
>At the Richmond symposium the professor who gave the lecture on turning tool steel used one of those to test the cutters. He ran the machine with the cutter until the cutter got dull. As far as I can tell that's the only good use for that thing.
Built my own
Texian
>Saw the Ringmaster at a woodworking show about 26 years ago. Went home and built a slotted wooden jig to bolt onto my single tube Craftsman. Worked great with a parting tool made from a long, thin slicing knife that my sweetie did not want. BTW I still use that parting tool, but it's a lot shorter now.
Re: Built my own
>I just took a thin parting tool and cut up some platters that were mounted to the lathe. I just put a pencil mark on the tool rest so that I could replicate the angles. I made a 3 foot tall tornado using the stacked ring technique. I cut up a whole bunch of platters varying the ring size slightly and then just stacked them visually to give the random shape of a twisting tornado.
Marc Phillips
>I was at a craft show and there was a guy there with about 100 bowls all made with a ringmaster...
..... and every bowl was the same size, color, shape, and lousy finish as the others...
You suppose he actually sold enough to pay for the booth?
Eduardo sarmiento-hall
>I had one in the 80s it did cut nice rings but like the man say they were all the same,craftsupply uk sells the tool for making rings,is a metal tool rest with the angles on it and the parting tool pretty expensive ,my2cents
Re: Built my own
Texian
>Sound like fun John. Do you have a picture of it?
