>Of the available tools on the market it seems you can get anything from a 10 TPI cutter up to a 20TPI. Can anyone shed any light on the differences between cutting threads with a 10 or a 20. Is one easier to work with? Possibly less chance of cross threading? ETC.
>That's what I've heard but the jury is still out. I'm learning hand chasing right now. I only have a 20 TPI but will make a 10 or 12 in the next week or so. The courser the thread the faster you have to move the tool but I think they would cut more aggressively as well. The 20 takes many passes to get to full depth. I may not be pushing hard enough however, I am learning. If your lathe doesn't slow down below 500 rpm 16 to 20 tpi is probably a good idea.
I urge you to try it. It's fun. Like anything else don't try it on a finished product. My friend who got me started said to take a weekend and plan to spend a lot of time learning it. What I've done so far is to go into the shop each night and turn a thread, good or bad doesn't matter, just practice. I'm using PVC pipe and I do one or two short inside and outside threads each evening. It only takes a few minutes (OK maybe half and hour) I'm getting better. I'm going to switch to wood tonight and see how some Osage Orange threads.
Finer threads are easier to chase, because the chaser does not have to move as fast as coarser threads; however, coarser threads will work better on woods that are not as hard and dense as is required for say 20 tpi threads. I recommend that you try thread chasing in PVC pipe or pipe fittings or perhaps Corian. Once you get the hang of thread chasing you can do it in some of the softer hardwoods, but the real secret to learning to hand chase threads is a hard dense material such as box wood or African Blackwood, or as I mention pvc pipe or corian.
Another thing that helps is to lubricate the wood with a good paste wax. Keep it lubricated as you continue to chase the threads and you will have less crumbling threads.
Also, if you only have some of the softer hardwoods to work with, I recommend that you orient the grain of the wood perpendicular to the axis of rotation of the lathe. This was the threads have some endgrain and some side grain and seem to stand up much better than when the grain runs parallel to the axis of rotation.
>Well, I have never hand chased threads, but one difference is in when it comes time to adjust for getting your grain to line up. With 16 tpi, you only have to take off a maximum of 1/16 inch. With 8 tpi, up to 1/8 inch. That is a lot of wood on some boxes.
>Your correct although I usually never have to take off more than about 1/4 to 1/2 of the diameter to get the pieces to align. so on an 8tpi thread that only means 1/16 to 1/32.
One advantage to 8tpi is the you can make the threads sloppier to allow for more wood movement. This means you an make larger threaded pieces. With the 16tpI that I am currently using on my Baxter threade the thread depth is only .030" so in reality you only have about that much wood movement. I use dry wood of course for boxes but they do move seasonally. If you made a box 4" in diameter you could easily run into a situation where the lid might not fit. With 2" boxes this would rarely be a problem unless you build them out of Madrone or something really unstable.
