I need a finish...
I need a finish...
I need a finish...
Marc Phillips
>I really need recommendations on a good bowl finish... I have been using Briwax or just polishing with the Beal or sometimes using a wipe on poly...
I have read a little on Waterlox... and also tung oil followed by a Beal buffing...
What do y'all use?
Re: I need a finish...
Sean Troy
>I use Mahoney's Walnut Oil 95% of the time and like it better than any other finish I've used on bowls. I've been using it sense Mike came out with it on a lot of bowls with no complaints.
Ronald Nelson------WebKitFormBoundaryLbKh5mhsWidBX
>Best Finish ever: Velvit Oil. Barbara Gill sells it.
Bush Oil
Don Orr
>May not be available everywhere, but it's made right down the road from me. Woodcraft may carry it. Great product. Basically a Danish type oil with a high solids content. Penetrates very deeply and cures well. Does not harden in the can. I've been using it for years with great results.
John Veerkamp,Western Mo
>I second the Mahoney oil, I follow up with Renaissance Wax. It adds just that last extra depth and luxurous feel.
John
Re: Bush Oil
Donna Banfield
>I second Don Orr's recommendation for Bush Oil. In the past I used Woodcraft's Urethane Oil, but it would harden in the container if not used within 6 months. This was even after using the stuff in the can (I think it was called Blo?)that you shot into the container to 'keep the air' out and drying the finish.
Bush Oil gives me the same long-lasting finish, but does't harden up like the Urethane Oil in a few months time. I put the stuff on my bowls for food use, and have a couple of walnut salad bowls that get used 3-4 times a week in my kitchen. They've had about 5 years of use now, and the finish still looks good.
Ron McKinley
>Watco Natural applied on the lathe and buffed out/dried while it's spinning. Then run it through the Beal Buffing System.....Ron
