chainsaw chain
johnnie lewis
>I got a calog from baileys to day thay have some good prices on there chains are thay any good also what kind of chain is best for sawing bowl blanks i have a husky rancher with 20" bar thank you
chainsaw chain
johnnie lewis
Re: chainsaw chain *LINK*
Mike Jones, Redding, CA
>Mr Lewis,
Anything from Bailey's is good. The link below might help you select your best chain and has some very important safety info too.
Good reading...
Safe Cutting
http://www.oregonchain.com/sawch.htm
Re: chainsaw chain
Ray Binnicker
>I was told a long time ago from an "old" friend that Oregon chains were the best. I've been using them since. I think the chains that Husky package with their name on the box are actually Oregon chains, but not sure.
Ray Binnicker
Re: chainsaw chain
keith tompkins
>After using Stihl chains, that's all I buy. They produce all their own chains and bars, and, in my experience, they outlast everything else.
Re: chainsaw chain
George Van
>Johnnie, since my bowl blanks are relatively clean, not dragged through the dirt, I prefer a chisel tooth chain. They cut more aggressively. If I am going to be bucking logs at the landing on skidded timber I use a semi-chisel chain as they cut longer between sharpenings in dirty wood. I prefer a professional chain as I am trained and FISTA certified, they do cut more aggressively and are necessary for good plunge cutting. For just bowl blanks and the questionable holding power of the blanks while you are cutting them, you may be better off with an anti-kickback safety chain, that will be your decision based on your skill judgment. Best to always wear safety gear no matter what chain or saw you use.
Re: chainsaw chain
Dick Coers
>Another vote for Stihl brand chain. It far outlasts Oregon in hardwood based on my experience.
Re: chainsaw chain
Roger Dunn
>Bailey's are good people as are Madsen's up here in Washington. I second what George said. In addition to a chisel chain, look for a full skip or semi-skip for better performance while ripping.
Good luck
Roger Dunn
NOT Something to buy based on price!!!!!
Brad Vietje
>Whoa, Nelly !
A chain saw is something that can kill you. If you are not careful, mindful, and alert at all times during use, it WILL kill you. Johnnie, you are right to ask which ones are good, and have a good track record.
A smart person will buy the best chain, regardless of the price. Whatever I might save on a bargain chain is just not worth even thinking about. Take the advice of the professional wood cutters, foresters and loggers here, and buy the best chains you can. Otherwise, you are quite literally betting your life that the cheap-o chain is made just as well as the top brands are.
Buying chainsaw equipment based on price is like an electrician buying their rubber safety gloves from Wally-world because the look-alikes cost a little less than the real deal. Yeah -- right... not me.
Safe spinning,
Brad Vietje
Newbury, VT
what is the safety issue?
>I primarily use Stihl chains (I like the quality) but buy them at the periodic 1/2 off sale at the co-op.
I've had cheaper chains which seemed to wear out quicker and I suppose poor QA in dimension or pitch might accelerate sprocket or bar wear. However, I don't understand how a cheaper chain could be less safe than an expensive chain.
John, That Was My Reaction Too
Barbara Gill, Remlik VA
>How could a cheap chain kill you any faster than an expensive one?
Re: chainsaw chain
schembari3
>Stihl, Oregon, and Woodsman (Bailey's brand by Carlton) are all good chains.
I would not advise the casual user to run full or semi skip chains. These are aggressive, and do not have ANSI anti-kickback features built in.
Back to the original question: The Husky 455:
Read the side of the bar and it will have the key numbers stamped: Pitch (probably .325 or 3/8), gauge (.050 or .058) and # of drive links (78 would be my guess).
Order based on these specs. Full or semi chisel, whichever brand fits your wallet.
While you're ordering, order yourself a set of chaps if you don't have them. They start at $51.95 which is just $1.95 more than the average ER copayment.
Re: John, That Was My Reaction Too
Brad Vietje
>John, Barbara,
I'm not familiar with the catalog that was mentioned in the thread, and its entirely possible that all they sell is high-quality equipment. I also use Stihl chains, and if given the opportunity to buy at 50% off -- that's a good thing. BUT, I would not buy a no-name chain just because it costs half as much.
Maybe I was having a bad day... I guess this topic came up after dealing with a "customer" who was describing problems with some cheap-o Chinese-made mail-order junk instead of buying a higher quality item (as in, from some nice dealer like me...). My basic policy is that one should never scrimp where safety is concerned. I sometimes claim to know a fair amount about turning, but have always bought one brand of chains (Stihl), so I may be guilty of not knowing much at all about chainsaw safety equipment. I'd rather err on the side of safety, but maybe I'm going a little too far on this one.
Here's my (faulty?) logic: If a cheap-o chain is made from cheap-o metal (a pretty good assumption, I think), instead of just wearing out faster and not lasting so long, could it not wear at all the little joints, and actually come apart faster? Maybe not; but that's what was on my mind.
Back to pruning Apple trees...
Brad Vietje
Newbury, VT
>I have used a chainsaw debarker for almost as long as I have been running a sawmill (23+ years). I have been using a chainsaw as long. I always used worn out chains with the debarker as to use a good chain would be a waste. Over the years I have lost count of how many chains have broken while I was debarking. Never has one of the chains even come close to me more less threatening my life.
I more than agree that good equipment should be used and everyone using a chainsaw should have training but over enthusiastic scare tactics do nobody any good.
>If a chain breaks or comes off, it just stops.
I think the biggest difference between chains is the hardness of the steel. Stihl seems harder than others, i.e., Oregon. This means it will stay sharp longer (unless you touch dirt or metal of course). However, for those who sharpen with a file, the harder steel is more difficult to sharpen and will wear out files quicker. This makes no difference if you sharpen with a grinder (or have someone else sharpen!)
As for safety differences in chains, Stihl makes "green" and "yellow" chains. The green have a feature to make them less grabby, although at the expense of a less aggressive/efficient cut. A person new to chainsaws or who uses them casually might use the green. The yellow chains cut better.
As for chainsaw safety in general, I think there are two biggies, neither related to the quality of the chain: kickback (which can cut you severely) and hazards related to felling trees. I think the tree-related hazards to be far more threat than the chainsaw itself since so many things can go wrong. I read statistics once that far more people are injured or killed by trees, falling limbs, and falling from trees than are by getting cut by the saw.
Of course, the biggest hazards of all are the same for nearly any tool (or sport or vehicle or firearm or electricity or nearly anything): ignorance and carelessness.
Exactly
>The chain falls to the floor.
Gary Evans Tallassee, TN
>When Cole was in the hospital from his motorcycle accident, there were at least 3 different guys in the intensive care unit who had been injured in logging incidents. 2 had fallen out of trees and the third had been hit by a falling tree.
For what it's worth,
Gary
George Van
>"2 had fallen out of trees" I tend to cut my stumps lower ;-))
>A good friend of mine died from a tree accident. He had climbed and and trimmed hundreds of trees and was one of the most cautious persons I've ever known. This tree had an internal flaw that was undetectable from the outside. While descending, the tree broke and he went down with it.
I watched a neighbor knocked to the ground by a large limb dislodged from a tree far from the one being felled. He got many stitches in his head at the emergency room and was VERY lucky. This is a good reason to always wear a hard hat. I like the all-in-1 head, face, and ear protection helmets - these are available starting about $50.
