Delta 46-460
Delta 46-460
Delta 46-460
>In the fall of �08 I learned through a friend that Delta was planning to release a new Midi Lathe. He was teasing me saying that they were building a small lathe with features typically found on a larger lathe and I immediately volunteered to test it. When I received a phone call asking me if I would be interested in demonstrating this machine, I immediately said, �Yes!� Shortly after the call the lathe was delivered to me in two big boxes. I put the lathe in my truck to take to my Guild meeting that night to allow my friends to have a look. I set the parts up on a bench and if I had been a salesman I would have sold two or three of them that night.
At first glance you may not see many differences in this lathe compared to the old Midi but there are a lot. Delta has moved away from their typical solid grey paint to a marbled Grey look. They installed a new 1 HP motor (on the 46-460 that I tried) that is conveniently located an extra inch or so below the bed which makes for easier removal of woodchips.
Most of the changes have been made in the Headstock. The swing is 2 �� bigger than the old Midi. This allowed me to use the Jumbo Jaws from Oneway. The controls are still on the upper left hand side and the on/off button is now larger, make emergency stops easier. There is now a Forward/Reverse switch in front of the on/off switch that will not move with the lathe operating. Directly to the left of these two switches is the variable speed dial. It is numbered one to ten allowing you to not only quickly recognize the turning speed but also to return later to a work piece and pick up at the correct speed. All of the electronics are protected by a 10 Amp breaker on the back. Upon further inspection of the headstock what I thought was the lock down pin turned out to be a 24 pt. indexer. Also installed is a lever that locks the motor, allowing you to release the tension on the belt so you can move the belt over to one of the three pulleys, saving your fingers. The spindle is still 1x8, compatible with the faceplates and jaws from your old Midi. They have also maintained the #2 Morse taper on the spindle. You cannot outboard turn on this lathe but if you wish too, I would recommend buying a bigger lathe.
The Tailstock is much heavier than its predecessor. The Quil travel is 2� and has a #2 Morse taper. The levers to lock down the tool rest and the tailstock are longer and easier to use. The bed has been machined to have more grip. It almost sounds like a zipper when you move the tool rest or the tailstock but is still smooth enough to make sliding easy. This prevents the stock from travelling when you screw out the Quil. A quick test with two center points showed that the lathe has been machined with perfect centers between tailstock and headstock.
A bed extension and legs came with this lathe so I installed them on the lathe in my shop. The legs are made from steel tubing 2 �� square and add to the already heavier lathe body. I found the legs to be easy to install and quick to set up. The extension was a little tricky to install so I wouldn�t want to do it all the time. The extension has an interesting feature as the end of the extension has also been finished. This allows a person to install a second or even third extension making the lathe as big as you need or want.
I used the lathe for over 20 hours in my shop and at the demo, to turn things like an 11�� bowl, pens, and of course tops for the kids. I found the features they have added or changed make it a small lathe that has big capabilities. It was very enjoyable to use and I am sad to have to give it back. The lathe is rumored to be available in Canada in May with a list price of approximately $700.00 CDN. This is an estimate provided by a Delta representative. If you are interested in a lathe of this size, your decision should be easy. I recommend the well designed, heavier and very well built Delta 46-460.
If you have any questions about the lathe please feel free to contact me or Delta.
I do not work for Delta and the opinions expressed in this are my own.
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
Re: Delta 46-460
David Walser
>Looks like a very solidly built lathe. It's good to have another worthy competitor enter the market.
Re: Delta 46-460
Re: Delta 46-460
keith zimmerman, Normal IL
>Thank you Derek, I have been looking forward to this. I can hardly wait to see one of these new midis. It has so much I have been wanting that is almost seems to good to be true.
keithz
Re: Delta 46-460
Any idea when it will be out?
Re: Delta 46-460
Re: Delta 46-460
schembari3
>Our Turning club has the same lathe, with a 3/4 HP motor. Other than being a little underpowered (it draws the amps of a 1/2 hp) it is a great machine.
Street price should be under $500.00 and they are ready to ship. According to Delta, the marketing dept has not set a price for the bed extension or other accessories, but it should be available within a month or so.
I don't work for Delta either, but it seems they got this one right.
Re: Delta 46-460
Re: Delta 46-460 *LINK*
>Here is the new Lathe and accessories.
http://www.deltaportercable.com/lathes/midi_lathe.html
New Lathe Link
Re: Delta 46-460
Re: Delta 46-460
Mike Brazeau
>Nice piece of design and marketing. Some video segments a little rushed in video shooting though. 80 grit tool plays a prominent role a bit too early in the platter segment. Looks like Delta wants back in. Having seen a couple of months back, can say they are telling it like it is.
Re: Delta 46-460
Re: Delta 46-460
Norm Smith
>F rom what I see, this lathe looks good. if so, it is the first good lathe that Delta has made in a very, very long time.
Re: Delta 46-460
Re: Delta 46-460
>Glad to finally see some movement on this new lathe. It appears as though the 46-460 VS is available now, but the stand won't be available until Summer 2009. Kind of strange to me that they would have the lathe available before the stand. Guess I'll have to wait until I can get a stand before buying one, especially since I don't have room for a workbench to mount one on. My closet isn't that big.
Thanks for posting the link.
keithz
Re: Delta 46-460
Paul Kramer
Are they actually available anywhere?
Paul Kramer
