Vacuum Pump
Vacuum Pump
Dick Hines
Vacuum Pump
Dick Hines
>Ok, you guys got me into trouble last night. The subject of vacuum pumps came up and I got talked into getting one. I looked on the Surplus Center sight this morning and the only have one I think would work.
Can one of you vaccum experts look on the Surplus Center at item 4-1669 an let me know if this will work.
Thanks.
Re: Vacuum Pump
Re: Vacuum Pump
Harvey Brooks, Victoria, BC
>That's the one I have and it works just fine.
Re: Vacuum Pump
Re: Vacuum Pump
Bill Gasper
>I'm also looking into vacuum pumps. The pump Dick found at Surplus Center pulls 4 cfm and 20 in. Hg. Is that enough? My understanding is you need 6 cfm and 24-26 in. Hg? Just want to get it right - thanks.
Re: Vacuum Pump
Rob Wallace
Re: Vacuum Pump
Rob Wallace
>Bill:
Most of the rotary vane vacuum pumps sold with vacuum systems in catalogs (i.e. Craft Supplies, Packard, etc.) rely on the Gast "23" series....with the 0523 being a popular model. This draws about 5.3 cfm (open input) and is rated about 26 inches Hg (max). These work quite well (I have two of these pumps) which have ratings below what you specify as the "required" vacuum levels. In practice, I adjust the vacuum (through leaking air into the system) so that the system is maintained between 16 and 20 inches Hg. The 20 inch Hg and 4 cfm would likely work OK - the cfm rating is not as important as the static vacuum achievable by the pump. The cfm values assure that the pump will continue to maintain the vacuum throughout the use period required and efficiently make-up for leaked air into the system. Remember that the vacuum systems are meant for finishing work using light cuts, such as those used for finishing bottoms of bowls, for sanding, etc., and only needs to hold the work securely, but without too much vacuum that implosions happen (DAMHIKT!)
Good luck,
Rob Wallace
Re: Vacuum Pump
Re: Vacuum Pump
Alex Stewart
>I posted a name of a web site which was www.yellow jacket.com a few weeks ago.
These guys are specialists . I personally repair a lot vac pumps in the Uk We have found that unless you change the oil very regular you wont get results . Refrigeration engineers change oil every job ,and don't use anything, but a good grade of vac oil. The intelligent ones will work this out.Some old pumps I have tested have pulled 12/15 microns that is what you have to work out the convertions to ins" or torr. I hope this has been off some help. I must say comments on this site can be very helpful and informative .
Alex
Re: Vacuum Pump
Rob Wallace
Re: Vacuum Pump
Rob Wallace
>Hi Alex:
I would advise staying away from oil-jacketed vacuum pumps for woodturning vacuum-chucking applications - I've gone that route using a very expensive laboratory grade vacuum pump, and the dusty environment around the lathe does not sit very well with the pump or its internal mechanisms, even if extra precautions about filtering, etc. are followed. Constantly accumulating 'sanding dust and oil mixtures' are not good for the working parts of the pump. Being the "tool-handy lab rat" all through college and grad school, I've rebuilt a number of laboratory vacuum pumps since the early 1980's, and for woodturning, rotary vane pumps are the only way to go for vacuum chucking. Newcomers to vacuum chucking should try to stay away from oil-based pumps unless this is the only way to get started.
Rob Wallace
Re: Vacuum Pump
Dick Hines
Re: Vacuum Pump
Dick Hines
>The pump I am looking at is oil less. I just want to know if it has the power to work with a vaccum chuck system.
In my shop anything that is not good around dust is in trouble.
Re: Vacuum Pump
Re: Vacuum Pump
Sam McGarrity, Cape Coral, fl
>Dick--I just bought this pump and it works just fine--Gast rates this pump at 4.5 cfm and 26 in. The pump I got looks brand new. If you need any more information e-mail me.
Re: Vacuum Pump
Re: Vacuum Pump
Alex Stewart
>Hi,
Rob you make a good point, not one that I thought of ,our club cobbled together a chuck one night but I didn,t think it was any good our chuck that is and it never was attempted again maybe we should
Re: Vacuum Pump
Dick Hines
Re: Vacuum Pump
Dick Hines
>Are you sure we are talikng about the same pump?
Here are the specs: 4CFM at 0 in.Hg
20in. Hg max vacuum
PSI 10 cont
PSI 15 Max
I am ordering parts for the system just need a pump.
Re: Vacuum Pump
Re: Vacuum Pump
Carole Valentine
>Dick, I don't think that's the pump most folks have been using. Specs (and price) are too low. The one I looked at when I was thinking of buying one pulled more vac and was about $89. I don't see any of them on the web site.
Re: Vacuum Pump
Dick Hines
Re: Vacuum Pump
Dick Hines
>You are right. They don't have them anymore. I guess I waited to long to do this vacuum thing.
I know I am not going to drop $400 on a pump. I will stick with my MDF jam chuck first.
Re: Vacuum Pump
Re: Vacuum Pump
>Dick e-mail your phone number and I will call you. I'll give you all the information I have; I just went through this whole thing.
Re: Vacuum Pump
Re: Vacuum Pump
Carole Valentine
>Talk to Jeff. He talked to the Gast people about those pumps. 20" might be enough. The vacuum generator that HoldFast sells that runs off a compressor only pulls 19". The Gast people told him that the problems with those pumps is that the vanes get brittle if they have sat around for a year. He also said that if they are going to break, they will do it when they first start up, and they have a 90 day warranty at Surplus Center.
Re: Vacuum Pump
Mike Peace
Re: Vacuum Pump
Mike Peace
>Dick, I understand that many folks have used the model you identified successfully. That said, I would urge you to carefully check out buying the newer Gast 523 110 v model off eBay. I bought mine with shipping at less than $100 and it is 110v. It was used but one of the newer 523 models like the one CSUSA or Packards sells. The newer 523 come with internal filters that save you a few buck over the 522 220 model from Surplus Center. It is also cheaper to put an old PC power cord on the 110 pumps than buy the plug for a 220 v. model. Be patient and you will find one of the newer 523 110v models used at a good price off eBay.
Re: Vacuum Pump
Rob Wallace
Re: Vacuum Pump
Rob Wallace
>Dick:
I will also agree with Mike on looking at eBay for a Gast 0523 rotary vane pump from eBay - Both of my pumps were bought this way, and the first one I got (for about $ 135 and $ 26 shipping) was brand new, unused, in the original box, with factory seals still in the pump! The total I paid, including shipping, was less than half the price of a new pump. My second 0523 pump was purchased for about $95 and something like $ 19 shipping. As with everything on eBay, patience is a virtue. There are ALWAYS vacuum pumps offered; just know exactly what you want and keep looking...
Rob Wallace
