Have a question? Ask Woody!
Tailstock Relief....Aaahhhh
Cyril Griesbach
>A couple of years ago Brent English of Robust Tools asked me if I thought there would be a market for a tailstock Tilt-A-Way for the Powermatic. I said that I thought there would be because it�s a popular lathe with a very heavy tailstock and in any case there would at least be a market of one�me.
Well that�s about where the idea stayed for quite some time. Occasional emails to Brent about it indicated he hadn�t had the time to look much further into it. Then last summer at the Chicago Symposium we talked about it some more and he seemed truly interested in pursuing the idea.
A couple of weeks ago I got an email asking me if I want to �test drive� a prototype of the �Tilt-A-Matic�. Talk about a rhetorical question�I wanted to get in the truck and drive right down there. I�ve been using this prototype for a while now and I can tell you it is a real joy to have on the lathe. I move my tailstock on and off the lathe a lot with different projects and this is a real pain saver for my already arthritic back.
Here are a couple of photos. I have no business association with Robust Tools. This is a prototype and new units will look better in fit and finish and will likely include some small changes that I have suggested as a result of my evaluation. Robust Tools has generously allowed me to keep this one at a slight discount to the retail price. Thanks, Brent.
Re: Tailstock Relief....Aaahhhh
Re: Tailstock Relief....Another view
Cyril Griesbach
>Now that's exactly what I think a swiveling tailstock should do. I didn't like the swing away ideas because the tailstock is still in the way for some cuts. It doesn't happen to have a spring load tension device to make it easier to pick back up does it?
I'm afraid to ask the price because I'm going to want one. I don't think my machining skills are up to building one yet.
Dick Hines
Dick Hines
>Now that is cool. But is still looks like it would be in the way when doing hollow froms and big bowls off the end. I would like to give it a try though.
paul waddle
>Go ahead and ask price John,we want to know... Also,does it have adjustable stops so the bed alignment will be auto, and swinging stops so it won't swing on its own. How about an uncomplicated latch so it can't vibrate......pw
Jamie D
Cyril Griesbach
>John, sorry but no spring tension but swinging it is soooo easy. Go to Robust Tools for more info. I think he�s got it on the site.
Dick, it�s not in the way at all for hollowing or sliding the headstock and working off the end unless, of course, you�re using the bed extension and the extension banjo.
Paul, take a look at the underside photo. The ring you see is on a safety stop rod that snaps into two different hole positions depending on where the PM tailstock keeper is located. The have moved it over the years. It relocates to a spring loaded pin when brought into position for use but this one does have a slight amount of play. When I swing this up I slide it onto the ways a bit and tighten the unit with handle located near the turner which is like the one on your banjo tool post only bigger and adjustable in the same way
I agree, I think it should do both.
>It would be nice if it tilted over to the side like this one, and then you release a catch and swing it around to the back side. That way it would have the advantage of the Butler swinging tailstock and the Robust rotating tailstock. The Butler gives clearance for doing hollow forms but doesn't get the tailstock out of the way when doing other things where the tool might hit the tailstock.
The Robust gets it out of the way for all but turning while standing on the end of the lathe and might not be in the way as much as I think it would be.
How do you spell Relief....Robust
Ron in Drums PA
>I like it
Will he be adding ways on the swing-away? It would be nice when bowl turning on the end of the lathe
Re: How do you spell Relief....Robust
Cyril Griesbach
>"Will he be adding ways on the swing-away?"
Not that I'm aware of, Ron.
Bill Grumbine - Kutztown PA
>Dick, I am biased, since I own a Robust and am a dealer (public disclosure for the net nannies) but it doesn't get in my way at all, and has not gotten in the way of students.
John, it moves real easy, even without springs.
Ron, I don't know if he will add ways, but I don't know that the absence will be a big factor. My extra ways are 6" long, but I hardly every use them for the banjo. Usually the headstock is set back far enough that the banjo is on the main section of the lathe.
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>Here's the thing: I use a modified form of the Elbo hollowing rig for hollowing, and the modification involves a second banjo that sits on the lathe bed, often near the end of the ways, which would be near the swinging tail stock. This banjo sits on the bed "backwards", which is to say the tightening lever is on the far side of the lathe -- not on the near side next to the turner. So my question is whether or not this swinging tailstock attachment would get in the way of the way I hollow. From the pic it looks all right, but I'm not sure.
Ron in Drums PA
>Oh well, I was ready to be the first to buy one.
I guess I'll wait until the upgrade comes out.
Re: Tailstock Relief....HARRUMPH!!
Mike Jones, Redding, CA
>When I first got my Pm 3520 (almost two years ago) I thought that tailstock would be the death of me, and I sought relief early on. One thing led to another and soon enough a year had passed and I had neither made nor purchased a swing-away, fold-away, nor drop-away, tailstock handling device.
And now, at 69 years of age, with a beefy back and buff shoulders, biceps grown by a half inch, and neck a full size larger, I scoff at the very idea of you wussies and your labor-saving inventions.
(Harumph!)
Now that I think about it, I'm going to quit putting the tailstock on the bench and start putting it down on the floor so that I can build my legs in the process. And then...(perhaps)...a spot on the floor at the far end of the shop!
Yep! Do a few reps each morning before coffee...
(tailstock relief...harumph!)
George Van
>Thanks for the chuckle Mike!
If you need more exercise with those new muscles....I will be starting to cut, split, and stack next years firewood in a few weeks and would be glad to help your fitness program out and let you do it for me;-))
Ron in Drums PA
>You forget Bill, I'm a little shorter than you. ;-)
Brad Vietje
COOL ! but can he...?
Brad Vietje
>...also make it 12" or 18" long, instead of just 6 or so? That way, I get the bed extension I need, too!
Safe spinning,
Brad Vietje
Newbury, VT
