moisture meter evaluation
gary clarke
>I would like to know viewers experience with moisture meters. I am looking at delmhorst, lignomat, and general. I have a wagner which does not work well with many of the hard woods like African Blackwood.
All comments welcome. I will be using this for segmented work. thanks
Re: moisture meter evaluation
charlie belden
>You wanting a pinless or pins meter. For segmented stuff holes in the face of boards probably aren't a problem - for cabinet makers - different story.
The fun and games with any of the moisture meters is that YOU have to provide the specific gravity of the wood you want to measure - and that can get pretty messy.
Here's the problem - wood is sold by their "common names", not their latin scientific names. You can find the specific gravity of a wood IF you know the latin name - and are sure that what they told you you bought is in fact what you actually bought. And the "common names" are often used in a fast and loose manner. Get the wrong S.G. and the meter results interpretation can be off - by a little or a lot.
I've got a bunch of mainly quarter sawn "english sycamore" - which isn't actually a sycamore, but a maple. Problem is, it may be one of three possible maples - the S.G. ranging from something like 0.49 to close to 0.75.
Sorry to add to your decision making task.
>If you have an accurate gram scale and a small oven you can always measure the moisture precisely with the oven dry technique, no moisture meter needed but you do need to sacrifice a small sample.
charlie belden
But if you take your sample off the end of a board - it's probably going to be drier that another area of the board a foot or so away.
If, on the other hand, you can weigh the whole board, record the date and weight, and periodically repeat the process until the weight stops changing - you've got wood with at its equilibrium moisture content.
Problem is - if you don't store the wood in the interim, in the environment that it will ultimately "live in" - you probably will make the piece under one condition - where it will remain fairly stabile- and then give it a home with a different condition.
I'm curious about how segmented pieces hold up over 10 or 20 years.
