>I really want to thank all of you who recommended this lathe to me... I got it set up and just turned a piece of red cedar and I cannot believe how smooth this machine is... I am really looking forward to putting the largest chunk of wood I can dig out of my wood pile on this rascal and see how it does... I think the tailstock weighs more than my entire Jet 1236 ;)
When you finally take a break from turning and come up for air (and wipe that silly grin off your face!) a quick mod may save you some future grief. Unless they have changed the switch design, the open mechanical parts are subject to clogging with fine dust and the switch is a pain to disassemble to clean. The electrical part of the switch is a commercial microswitch, but the mechanical part is a spring-loaded ball and detent design - that's what can get clogged. The local Jet service guy told me he has seen several with this problem.
After the first time, I devised a fix. I wrapped the back of the switch with plastic stretch wrap and taped it into place to seal it and keep any dust out. (The back of the switch is accessible by removing the two screws on the switch plate.)
Also, if you should get a catch big enough to stop the motor, it is likely that the drive will appear dead with an error code displayed on the controller. Don't panic, just pull the plug, wait a few seconds, then plug it back in.
>Good to hear you like the machine. I've had one for several years and have never had a problem. I've worked it pretty hard many times. I hope it gives you many years of enjoyment.
>Yep... that set up looks very handy indeed... currently I have one of those Sears 5 drawer rolling tool chest thingies that holds all the lathe stuff... that sure looks a lot better use of the space... Thanks!
