>so ive got the ms 361 runnning and have been learning about how to maintain it... recently i had a problem where after the saws' fired up from warm start, I blip the throttle trigger to set the saw at idle. Instead of idleing, it just shuts off... stops.... weird?
>Hi again Clay -- try a slower squeeze on the trigger when you initiate your "blip." I've had pretty much the same experience; they just don't seem to like being given too much too fast.
That might change after the engine breaks in a bit. Seems like mine needed babying at first, but not any more - I can rev wide open as soon as it starts, engine hot or cold. But I don't think it's normal - if that problem continues, you might need the carb adjusted a bit.
BTW, one thing to watch for on any chainsaw - every time you add fuel check the remaining level in the bar oil tank. Ideally it should be almost empty. If completely empty it might be pumping oil too fast and the bar could be running dry before the gas tank runs out. If not nearly empty, the oil system might be clogged or the oil delivery might need to be increased, adjustable on that saw. I had to crank up the oil delivery a bit on my 361 when it was new.
On another Stihl I have, the pickup in the tank once got clogged after a few years of use. (This comes from not properly cleaning around the cap before removing to fill - it's good to blow away the crud with compressed air before leaving the shop and clean with a rag during the day. It also helps to wipe away any oil spilled around the cap after filling so it dust won't accumulate.) When flipping the bar every few sharpenings, clean the oil holes and grooves as well.
If the oil is not supplied properly you can quickly ruin the bar and chain from the heat. Every time the saw is started for the day (and occasionally during the day) it's good to test to see if the chain is getting oil - hold the tip a few inches away from a clean surface (such as a piece of wood) and rev the saw wide open. If the bar is getting oil, some will be thrown off the end of the bar and you will see an oily line on the target.
The link below has some information on mods for your saw. The 361 is a very popular saw and there is a lot of information on the net. BTW, I use a 24" bar on mine which makes it a little bit unbalanced. I do 95% of my sawing with a smaller saw (MS250) with a 16" bar. The 361 will easily handle the bigger stuff though - right after I got it I cut up a 48" white oak for a guy and the saw never complained. (The main trunk was way too big for my sawmill but I got a lot of great lumber from a couple of "limbs"!)
>You must be spoiled with the modern car engines controls. Heck, I remember having to start my car a few times some mornings, choke not set, not enough choke, choke stuck, choke cable not pulled out far enough for the cool air after starting..............Now if they could just get a good fuel injection system with a computer, oxygen sensor, exhaust sensor, air flow sensor, maybe another computer, well it would start first pull and stay running. That chain saw would cost $2000 and would have to get hooked up to a diagnostic computer for a $300 service call. Just baby it a little while new. I like to let them run about a minute before hitting the wood anyway. It lets all the parts reach the optimal clearances for best performance and minimal wear.
>tend to be on the lean side of the scale to meet emissions regulations.
When you blip the throttle while the engine is cold, the mixture can go too lean to continue running. If you still have the problem after the saw warms up, then take it back to the dealer for some carb adjustment.
I don't know if this applies here, if you ran out of gas the last time you used the saw, it will do that most of the time, then you start it again and it will star as usual,
