Poulan Chainsaw?
Poulan Chainsaw?
Poulan Chainsaw?
Ruth Niles
>Having problems with my Poulan chainsaw. I think it's running too slow, it shuts off when I release the throttle. I put clean oil/gas mix, cleaned the air filter and checked the spark plug (it's clean). The instructions say to turn a screw to speed up the idle, it has to be done while the saw is running.
Two problems:
I can't hold the throttle and turn the saw on its side to access the screw.
It's a hex screw, it's 2" down, I can't tell if I'm turning it or not.
Any suggestions?
Wish I could afford a real chainsaw, this is beginning to feel like a toy!
Re: Poulan Chainsaw?
Charles Watson------WebKitFormBoundary+ATeQdvhmFc4
>Has the gas filter been replaced lately?
Mike Jones, Redding, CA
>Finding the high speed "sweet spot" required two of us. One to run the saw, the other twiggle the adjuster screw. Not so with the low speed jet. Adjust the screw, run the saw...shut down and repeat.... until the idle speed is how you like it.
What Charles said RE: the fuel filter is good thinking too. You'll need some long tweezers, hemostat or be very adept with chopsticks, but the filter is at the end of a tube and is inside the fuel tank.
Found the problem................
Ruth Niles
>The reason I could not reach that screw to adjust the carburator is because it fell out! When I shook the saw real hard (thought that might make it work!), I heard something rattle so took it all apart. That little screw must have been lodged somewhere in the bowels of the saw! I called Poulon customer service and they told me how to reset it to factory setting and it's working again.
whew, I'm having 8 pine trees planted tomorrow and have to cut down 3 small maple trees.........did not want to do that with a handsaw!!!
So.......
Jim Shaver - Oakville, Ont
>So.....You had a screw loose??
couldn't resist..
take care,
Jim
Re:I wonder whatever happened to......
Jamie D
>... the guy who used to catch so much Poooolann flack? I can't recall his name, but he seemed to be a good guy.
Re: So.......
Steven Kubien
>Cheap shot Jim. I like it!
Steve
Brad Vietje
I reckon' that would be BubbaBob, Jamie...
Brad Vietje
whoa,..........a cheap shot?
Ruth Niles
>.......and from a hockey puck?!?
sorry, Jim,
as you said, I couldn't resist
She Shoots......
>Thanks Ruth, I deserved that kind shot, but I have it covered..
Photobucket
We all love you to pieces Ruth...glad you had the spirit of my fun in your understanding of my poke.. LOL
Take care,
Jim
