>This picture is my version of the very popular CiL easy roughing tool. The original tool is made from stainless but I made mine from steel.I have several carbide cutters so I wanted another tool so I didn't need to change carbide cutter so often. My tool cuts just as good as the one I bought because it has the same carbide cutter. The price of my tool is under $14 whereas the original tool I bought was over $230, I believe, for the tool ,handle, cutters and shield. Both are good deals. Some turners hate to sharpen I love to sharpen, but dislike to change cutters, go figure why. Mitch
The carbide cutter that I have on this tool I made was the four sided square cutter that has no radius of any kind, I have two of these cutters and one with a 4" radius and one with a 2" radius. this is good for roughing. Mitch
These cutters aren't in mm, they are approx 5/8" square and probably 1/4" thick. The sides are beveled and probably sharpened at 45 degrees.Yes of course there is a difference in straight cutters and radiused cutters, depends what your doing at the time which cutter you will be using. If your plunge cutting you would be using a straight square cutter. Round cutter would be used in inside finish cutting. Mitch
