One more for Mike
One more for Mike
Dick Hines
One more for Mike
Dick Hines
>Another madrone box. This is the last piece I am out of madrone, for now. The box is 2 3/4"D X 4 1/2"H.
The finial is #6 ground wire, . What else. I ground it to a point and then heated it to cherry red. The bent it. Once it is worked it will reharden.
Re: One more for Mike
Mike Stafford
Another hot BOX!!!
Mike Stafford
>Dick, you may the first to incorporate wire exactly this way into your turnings and they sure do make a statement. I am surprised at how versatile a material wire is. Next you need to figure out a way to patinate the copper wire so it develops that wonderful verdigris color. I think that might look great on the right woods.
A terrific box, Dick. You are giving me ideas....I might have to use some big aluminum wire I have...Just kidding!
Dick Hines
Re: Another hot BOX!!!
Dick Hines
>I hear copper will turn green if you pee on it.
Cyril Griesbach
>Wow, Dick, that's just great work...both of them. Please find another way to patinate that wire.
Mike Stafford
I ain't buying that box.....!
Mike Stafford
>I'll let you do the experimenting but I am sure I don't want any boxes that are the result of those tests.
Dick Hines
Re: I ain't buying that box.....!
Dick Hines
>I have forun a place that sells chemicals to put patinate on copper. Ordered some this evening.
charlie belden
>From my jewelry making days
Oppi Untract's Bool - Metal Techniques of Craftsmen copyright 1968
Rich Reddish Brown on Copper
Copper sulphate 120 grains
Water 1/2 pint
Dissolve copper sulfate in water, heating if necessary to dissolve the copper sulfate.
Neutralize the solution with sodium nitrate
then add 150 grains of red iron oxide. Immerse the article in the solution until its color starts to change. Remove and heat on hot plate to deepen the color, Repeat for even deeper color.
Antique Green on Copper
Copper nitrate 4 ounces
calcium carbonate 4 ounces
Ammonium chloride 4 ounces
Water 1 gallon
Warm the article as well as the solution. Stipple solution on object with cloth or sponge. For color variations, immerse the treated piece in clean boiling water AFTER the green has developed.
Yellow-Green on Copper
Copper sulphate 48 grains
Ammonium chloride 48 grains
Calcium chloride 48 grains
Water 3 ounces
Applied with a brush and allowed to dry - 3 applications produces a uniform green patina
Bronzing Copper
Copper sulphate 400 grains
Water 2 ounces
Use warm, immersing object two or three times, wire scratch brushing between immersions. Depending on the purity of the copper the color may be light brown, terra cotta, purplish or dark brown.
Most lapidary and jewelry supplies shops carry "liver of sulfur" - yellowish rotten egg smelling lumps. Dissolved in hot water, produces browns to almost black on copper and bronze as well as sterling silver (which has copper in it).
Now I just have to remember if the "grains" are a unit of weight for weighing pearls or a unit of weight in the troy system (28.8 grams/troy ounce, 20 penny weights (dwt) per troy ounce, 28 grains per penny weight.
You get to do the math.
Steven Antonucci
Vinegar and salt will do what you want
steve antonucci
Mike Stafford
A much better solution than Dick's idea, Charlie!
Mike Stafford
Dick Hines
Re: A much better solution than Dick's idea, Charl
Dick Hines
>But Mike it is not as much fun, like writing your name in the snow.
Chemicals are on order.
