>i just got my stihl ms 361 and it wont start.... im very green when it comes to chainsaws in general as ive posted before regarding which saw to buy... i've followed starting procedures... its a new saw so im figuring i'm the problem... any help's appreciated thanks
>Some saws won't start if the chain lock/hand gaurd is not pushed forward. Also after 3-4 pulls mine starts to flood so I unchoke it and give it a pull. Usually starts right away.
>HI Clay, check out the owner's manual. The shop should have gone over the procedure with you before you left. On my saw, I have to pull the trigger, hold it in while I set the choke. Once it fires, release the choke, then when it starts, release the trigger lock. Call the shop, or take it back for instructions.
>Clay, you say you are green when it comes to chainsaws, so please get some instruction from a well seasoned and safety-conscious sawyer. It's probably the most dangerous tool you will ever use. Your Stihl dealer SHOULD have given you basic instruction with a gassed up saw before you ever walked out the door. That would have included stuff about the chain lock/hand guard, which is probably what's causing your starting problem.
Are you using the compression release? (press in) That makes it a bit easier to start, although the saw should still start fine without using it.
Make sure the procedure is right. I mostly use a Stihl 250 but if I remember correctly, my 361 needs the same starting procedure. If I don't do this exactly, both saws are difficult to start. If I use this procedure, the saws ALWAYS start, unless one's been sitting unused for half a year. (I do this so often it's without thinking, so I hope I wrote it correctly.)
- Hold down the trigger and push the control lever to the very bottom position.
- Push compression release on
- Pull the cord slowly until you feel the resistance of the compression, then release the cord
- Pull fast until you hear the saw "blip" (fire or try to fire once). This may take several pulls.
- Flip the control lever up one notch.
- Pull until the saw starts. On my saws this almost always takes three pulls in rapid succession, each pull as fast as I can make it. Occasionally it takes a fourth pull. If it takes more than that, something is wrong. Do not pull the throttle trigger while starting.
For starting, I like to put the saw firmly on the ground with my foot on the flat spot in the handle below the trigger and my left hand firmly on the hand bar, especially for the bigger saw. For the smaller saw, I usually start by gripping the handle firmly with my legs just above the knees, again holding the and bar firmly with the left hand. Do not try the "hold one-handed and drop the saw while pulling the cord" trick sometimes used by tree guys with macho attitudes and small brains - this can take a little less effort pulling but has been the cause of several accidents.
If the saw is flooded from trying to start unsuccessfully, remove the plug (it will be wet with gasoline) and pull several times to clear the cylinder, then wait a few minutes for things to dry before reinserting the plug. You can dry the plug with compressed air. Make sure it is not oily and if so, clean it with solvent and compressed air.
An old trick for reluctant engines: remove the plug and heat it up. Insert it quickly while still hot and it should start much easier. Some people will put the plug into another engine and run it until hot (the safest way); I've heated with a lighter or propane torch well AWAY from the saw and gas can. Don't try this with a flooded engine and plug wet with gasoline! Be extremely cautious with flame around gasoline or have your hospitalization insurance and will up to date.
If nothing works, check for spark. Be sure you have the right gas/oil mixture and the right fluids in the right tanks. Occasionally someone will put oil the gas tank and gas in the oil tank - not good! I'm assuming this new saw has run before - a good dealer will start and run it in your presence. If not, take it back and make them start it. A new saw may have oil in the cylinder or on the plug.
BTW, after starting, hold the tip of the bar down and a few inches away from a clean, flat surface such as a piece of wood. Run the saw fast (wide open) for a few seconds and make sure the chain is throwing oil. This checks the chain oil pump operation and that the oil passageways are clear. This shouldn't be a problem on a new and clean saw.
BTW2, for best engine life, use gasoline that does not contain alcohol, even if you have to drive around to find it. Bailey's (online) has an inexpensive tester to check the gasoline if in doubt. Mix stabilizer with the gas if the saw will sit for a while between uses.
BTW3, I've always wished chain saws had a socket on the side that let you start a reluctant engine by driving it with a shaft on an electric motor! This would also be great for old guys with elbow or arm pain.
>Hi Clay -- Much good advice here already but I'll add a couple items:
1) Brand new Stihls are harder to start than they will become after some use and "break-in" -- at least mine was, and I have seen others make the same comment
2) DO read the manual which has some comments about proper use during break-in period.
3) Use high-test gas but pump the first gallon or so into your car to get the low-test out of the hose from the last user. The no-alcohol advice is also worth following if you can readily do it.
4) Use Sta-Bil or other such stabilizer, or get rid of unused gas after a couple of months. I don't use my saw much so I use only a 2.5 gal. can, and if it's still 2/3 full after a couple months I start mixing it into the car's gas tank to get rid of it so I can treat the Stihl to only good fresh gas.
5) Get an experienced user to help you along -- a chain saw is plenty dangerous. Be afraid, be very afraid.
>some one to be afraid of a tool they are going to use. That sir is a recipe for disaster.
A chain saw is not to be feared just give it the respect it needs, not fear!!!!
I have wore out at least six chain saws in my life time and there is nothing to fear. Respect and knowledge of what it can and can not do is needed, not fear!!!!!!
Sorry Chuck but I just do not think it is good advice to fear some thing you are going to use.
>I think the thing to be very afraid of is what we don't know. Respect and knowledge is right, but the respect comes from knowledge - you cannot possibly protect against what you can't imagine could happen.
Unless you are felling trees (which brings a huge list of hazards), the most dangerous thing about a chain saw is kickback. Learning what causes kickback and the ways you can be surprised goes a long way towards safety. Cutting downed trees is considerably more hazardous than shaping bowl blanks in the yard. For example, you are part way through a nice, easy 12" log when you let the tip touch a 4" branch hidden behind the log - wham! Or a log shifts and you lose your balance amid a jumble of limbs. Or you rev the saw while moving down the log or stepping over limbs - I've seen "professionals" do this. The second most dangerous thing is a moment of inattention or distraction.
A good set of kevlar chaps will help prevent serious injury to the legs. Some wear steel-toed boots. I always wear the hard hat with face guard and ear protection. I'm amazed at the number of people who saw without even eye or ear protection - "I been doin' this all my life and it ain't hurt me yet."
I've mentioned this before - in addition to good info on various web sites, the book "The Good Woodcutter's Guide" can provide a crash course on chainsaw maintenance and safety, both with the saw itself and when felling trees. What you don't know CAN hurt you! I think that's the think to be very afraid of.
>Hi Denis -- I can certainly understand your point of view. Just to set the record straight, the intention of my choice of words was more to play off the horror movie trailer use of the phrase than to be literal about fear versus respect, and I agree that respect is a more generally appropriate term.
>I bought my saw in Nov., fired it up and then put it away. I didn't have anything to cut. Last month, while in Tucson trimming pruning and trimming mesquite branches, my saw started once (mid day) and then I couldn't start it again to save my soul. I tried starting fluid, cleaned the plug countless times, swearing, etc. both nothing worked.
Broke down and took it to a Stihl dealer and told them I couldn't start the saw. And I know all about engines. The kid took the saw and walked to the back, I walked maybe 10 feet to look at the bigger saws, when I hear the sound of a chainsaw. I turn around and ask the second counter guy of that's my saw. he takes a look and says, "yeah". I tell him it was supposed to take them all day, and a call to the Stihl engineers to figure out the problem. He said it doesn't work that way and that I haven't been the first guy (greenhorn) to come in with this problem.
It turns out on the Stihl, the full choke (butterfly valve fully closed picture on handle) acts like the primer button on other brands of saw. This position is just to draw fuel into the carb NOT to start the engine. Which is what I was trying to do. Which was flooding the blasted thing.
1. Set "Master Control" lever to full choke, pull cord to get a sputter, almost gonna start sound from the engine,
2. Set "MC" to almost full choke (gap at butterfly valve and intake opening picture on handle) Give cord a few good pulls and that great Stihl motor will fire up.
3. Set the "Master Control" lever to 'I' and get ready to cut.
Works every blasted time. I taught my wife these steps and she didn't have a problem at all.
What a dummy I was. Prior to this "training" I was ready to toss my new saw into the closest arroyo. I was really upset with it.
>Same story here Eddie (except for the mesquite. Silver maple in my case). I know nothing about the internal combustion engine and figure it is pure voodoo...like computers. Ever since the time I took my saw in and got told a few things, I've never had a problem.
