convex skew
convex skew
convex skew
>I'm going to be teaching the skew tomorrow to a guy who is going to demo for the club. He already uses the skew but wants to learn more. I spent about half a day playing with my skews. I have recently made 2 convex grind skews to learn what all the fuss is about. I made one with a 20 degree grind (bevel to bevel) and one with 35 degree. I chose the 20 because that is the way that skew came so I just radius'd the edge slightly which means it's probably closer to 25 actually. The radius on the 20 degree skew is very slight. On the 35 degree it runs the whole length of the bevel.
My normal skews are both 35 degrees which is what I prefer. One is a Thompson and one is a Sorby oval. They have a concave bevel that has been sharpened with diamond hones so the user part of the edge is flat.
Both sets of skews were sharpened so they shave hair (boy does my arm look funny) Anyway I turned flats, long concaves, long conves shapes, beads, balls and barrel shapes. I also used the toe of the skew to do a cut similar to what I do on the bottom of goblets and also V cuts.
I find all the skews cut the long curves, flats and coves about the same. Barrel shapes and balls were about the same but I had more trouble finding the bevel when cutting straight sided beads with the convex skews. The 20 degree grind worked pretty well on this cut but you better be good with he skew. I found the flat grinds much easier to control on the straight side.
I had a lot more trouble using the toe of the skew on the convex grind. I do this cut across the grain on the bottom of goblets all the time and it's an easy cut with my flat ground skews. I really had trouble keeping the cut in the wood with the convex. I'm going to try again tomorrow before he gets here to see if I can figure out what is different.
Sharpening was interesting. I raise a burr with the diamond hone and then flip the skew and hone the other side until a burr is raised, then switch grits and do it again. I felt like I was gradually increasing the angle of the radius. On my flat skews the hone rides on the toe and heel of the edge (since it's concave) so the edge stays the same angle through out multiple sharpenings.
I think I'll stick with my flat grind skews.
Re: convex skew
Re: convex skew
paul waddle
>Interesting John! I have enough problems with regular skew. I assume the round (end ?) skew is for delicate finial and bead work?
I don't sharpen my skew(just have one) as sharp as you,no wonder you can take small slivers-probably you don't need to sand finished pc.
I can't remember the professional turner that does that delicate finial work,wish I knew her name-seems it starts with a D ?. pw.
Re: convex skew
Cindy Drozda
arkie
>Cindy Drozda is known for her boxes and in particular the finials on them. I have seen more delicate spindle work than her finials. I'm not sure I've seen better composition and balance than her finial/box combinations.
Re: convex skew
Re: Cindy Drozda
>I agree. Her finials are really nice. I quit making really thin finials because the customers worry about breaking them and I've also had one broken at a show. I used to make my ornament finials really thin at the joints. I thought they looked great but almost every customer would ask "will it break" I usually said yes if mishandled, it's not much different than your glass ornaments. I finally just gave up and made them thicker. They sell just as well and I don't have to worry about them.
Re: convex skew
Re: convex skew
robo hippy
>I have been using the convex grind for a few months after seeing an Eli Avisera demo. It is supposed to be more user friendly. I have found that to be some what true. The biggest advantage I can see it that it is easier to do curved forms with it, like the transition on my basting brush handles. I also prefer it for cutting beads. I prefer the standard grind for cutting longer straight forms like a rolling pin. Being able to ride the bevel makes it easier to feel any dips and humps when going along a straight line. With the convex/rounded bevel, this is much more difficult. You never have to take one of the convex grinds back to the grinder, just roll it on your diamond stones.
robo hippy
Re: convex skew
Re: convex skew
Ron in Drums PA
>They way Alan Lacer sharpens a skew uses both methods. From the tip to the center is sharpen traditionally. From the center to the heal it is sharpen with a convexed curve.
I have two like this, a 1" skew and a 1/2" skew and I like use them a often.
Re: convex skew
Re: convex skew
>I turned with it a bunch more today. I still find the flat grind easier. I can't seem to control the shape of the cut as well on beads. I think it's because I don't truly know where the bevel is. With the flat grind I can find the bevel and then move the cut in the arc I want because it's very controlled. I don't know how to explain it.
It seems like they both work. maybe one is better than the other but I suspect it is more about how much practice you put in with the skew rather than the type of grind.
I did learn one thing. The way that I am sharpening the skew the convex grind gets convex in 2 planes really easily. Looking at it from the flat side it is convex from 12 to 6 and also from 3 to 9. This makes it harder to control on the long flat surfaces. I used a belt sander to sharpen the big one and my diamond hones on the thin one. The diamond hones don't make it convex as easily.
Re: convex skew
Brad Vietje
Re: convex skew
Brad Vietje
>John,
I'm trying to follow this, but having a little trouble. Are you producing a convex bevel (i.e., not hollow-ground on a wheel?), or a curved shape -- what Raffan refers to as a "radiused skew" ? From some comments I get the impression you are discussing a curved, or radiused, skew, but still hollow-ground on a grinding wheel. But now I'm not so sure. If you are experimenting with both at once, it may be tough to determine which change is responsible for an observed change.
Also, when you roll beads with a skew, are you using the long point (toe) down or up?
I still have one straight-angled skew, but the rest are all curved (radiused). I used to sharpen them all with flat bevels, but in the past 2 years have been sharpening them on an 8" wheel, which makes them easier to hone. Not sure I like the hollow ground tools better, but thought I'd stay with it for a while. I find the curved shape helps with peeling cuts (tool flat on rest), which I use a lot, especially when making tenons for chucking. I also use this a lot shaping box profiles. I have never found straight-edged skews as easy for these tasks, probably because more of the edge is engaged at once.
Thanks, and safe spinning,
Brad Vietje
Newbury, VT
Re: convex skew
Re: convex skew
>I'm not discussing a curve edge skew here. I'm talking about the bevel itself. I've tried the curved edge skew and don't see any advantage to it.
I like a hollow ground skew. I use an 8" wheel to sharpen and then use diamond hones to finish the edge.
I have been trying curved bevel skews like Eli Avisera recommends. So far I prefer my flat or hollow ground edge.
Re: convex skew
heel down
>I generally turn beads with the heel down. I will do one with the toe occasionally to keep in practice but I don't feel as comfortable doing it. If I haven't been turning in a while I may finish off a straight sided bead with the toe. it's safer.
Re: convex skew
Re: convex skew------WebKitFormBoundary9MDUHbnjko2
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>Yes,it's Cinddy Drozda, and her finials are indeed beautiful. But she doesn't do them with a skew; she uses a small spindle gauge.
------WebKitFormBoundary9MDUHbnjko24+NaZ
Re: convex skew
Picture or Drawing - Please
charlie belden
>I know what a "hollow grind" bevel is, and a flat, usually done on a flat stone or diamond plate, bevel. And I know you can have a straight cutting edge or a curved one on a skew. Having trouble visualizing a "convex skew" which sort of might imply a "concave skew"
Could someone clarify, preferably with a photo, a line drawing will probably also do?
