I am fairly comfortable with a lot of the different "stages" of turning a regular or natural edged bowl, with the exception of doing the bottom.
On a regular bowl I just use the Cole jaws and that seems to work most of the time...
.... but on a natural edged bowl I use various jam chucks... just wood roughly shaped to fit inside the bowl, and added padding to keep the bowl from getting scratched.
The problem I have is that I can't ever seem to get the bowl to spin smoothly... so I am assuming I just don't know how...
I would sure appreciate any tips and hints or links to a site or a video I can buy that will help me get a natural edged bowl spinning smoothly so I can finish the bottom!
>One of the best investments I ever made was an adapter that screws on my live center. You can take the chucked up piece, screw the chuck on the adapter and bring the tailstock up to center the piece. My first was aluminum but I got it stuck on a geared motor shaft and had to buy another. The one I now is steel and is more accurate.
They also have an adapter that is on a Morse taper but that will limit the ability of the adapter. When I turn a box, I put a tenon on both ends. I then will use my second chuck on the tailstock. Having the chuck screwed on to the live center allows you to do this. If it was fixed in the tailstock you would not be able to.
>Here is another way of getting your bowl to center when finishing the bottoms. When you start turning your bowl, you begin by shaping the outside and forming a tenon/foot. Before you turn your blank around to begin turning out the interior, try this: bring your tailstock up and put a mark or indentation into the wood right in the center of your tenon (assuming that you didn't already have the tailstock in place to make a mark).
When you're finished hollowing out the interior, and ready to finish the bottom, use your tailstock again to find the mark/indentation in your tenon/foot. That will help you get your bowl to running as true as possible, in much less time.
Here's another way to save some time and get to finish turning the bowl bottom right away. Forget spending the time to turn a waste block for your natural edge bowls; just use that same spongy/squishy material (I like old mouse pads and rubber carpet or rug pads), and place them over the jaws of your chuck. Serves the same purpose, and you've saved yourself 10-20 minutes turning a waste block or jam chuck.
>As Donna says, this doesn't have to be high-tech or expensive. In truth, it doesn't usually have to be all that precise, either, but you want to get it as close as you can.
I start all bowls between centers, and finish them all between centers, so I don't need the "chuck" that's driving the bowl to fit very closely. Like Donna, I leave the little stub with the mark from the tailstock when first turning the tenon, and use that mark to center the bowl for finish turning, or later for finishing the foot area. This "stub" has to be small enough to fit between the jaw slides when you compress the jaws -- usually 1/2" to 5/8" for me. It stays there until I reverse turn the foot area and apply finish. I either pad the chuck itself, or use a screw chuck insert with a few disks of wood or MDF in different sizes to drive the open end of the bowl. These disks are usually covered with a soft material like a light-colored foam to avoid marring the inside of the bowl.
These "bowl drivers" do not have to *fit* the bowl -- they just spread the contact area out to a larger circle so it runs close to true. The bowl probably will not run exactly true -- its often warped somewhat, and no longer round. No matter -- just finish off the foot, and snad and finish while still held between centers. Once you've re-turned the foot area, you may need to blend the round foot with the slightly oval area nearby. I do some of this with a shear scraper, and continue with a series of sandpaper grades. When parting the work off, cut away as much as you dare, leaving a tiny little plug supported by the tailstock. This is easily cut off with a sharp gouge, skew, or carving tool off the lathe, followed by a little hand-sanding and finishing.
I usually turn the tailstock support to about 1/8" for smaller pieces. and maybe 1/4" or so for larger bowls. I use pretty small 3/8" and 1/4" spindle gouges with long bevels for most of this delicate work. The more you do it, the more wood you'll dare to remove.
>See the Spring 2008, Vol. 23, #1 of American Woodturner Magazine. An article on the "Straka Chuck" starting on Page 50 might give you a good idea. On page 53 there is a picture showing a natural edged bowl mounted on the chuck. I am in the process of making one now.
