nova chuck insert
nova chuck insert
nova chuck insert
Hugh Widdup
>does anyone know where i can find/buy 1"-8 insert for a Nova titan chuck, does Woodcraft carry these?
Re: nova chuck insert
Bill Blasic
Bill Blasic
>Yes, Woodcraft carries that insert.
Mike Brazeau
>Hugh - have you tried KMS tools in BC? LV also carry Nova don't they.
paul waddle
>Where to get a set of spiget jaws for a talon and what ~cost? thks,pw
Ken
>They have them at PSI for 20.00 ea,I got two of em last yr an they worked great.
Steven Kubien
>Mike, Lee Valley used to carry Nova stuff but no more. If you go to the Woodworking index and click on Special Offers (or something like that), you will see that all of the Nova stuff they have left has been discounted. Not much left in the way of inserts and I doubt something as common/popular as the 1" x 8tpi would be available. Still, it may be worth the look.
Steve Kubien
jared
>I dont want to cross any lines here but email me, I think I can help you out. Jared
D. Hansen
>Try the source http://www.teknatool.com/
Ken
>I tried gettin em thru technatool for almost a yr and they couldn't come up with em.Thats when I found out PSI had em for 20 bucks.
Bill Blasic
Bill Blasic
>Ken,
Are you talking about a spindle adapter for $20? Big difference between spindle adapter and a Nova chuck insert or did I miss something in this thread and that has happened.
Bill
Ken
>Bill I am talking about a chuck insert/adapter for the nove chucks.If you look on teknatools site thats how they are listed and are for mounting your chuck with a 1x8 thread to a spindle w'1 1/4 x 8 threads.They all call them inserts,so that is what I was going by,but if I am missing something here,please fill me in.Heck I'm allways ready to learn something.
Thank ken
Re: nova chuck insert *LINK*
Gordon Seto
>Ken,
Which Nova chuck you have?
For example,the Midi is direct threaded; it has no insert. You have to use a spindle adapter to change your lathe spindle size to fit your chuck. If you are talking about spindle adapter, I don't believe Nova has one. A spindle adapter is a generic lathe accessory. You can find it in most woodturning catalogs.
A chuck insert is attached to your chuck and becomes part of the chuck.
G3, SN2 & Titan has inserts. You replace the insert for different size spindle lathe.
Insert D is for 1" x 8 tpi spindle
Insert L is for 1-1/4" x 8 tip spindle
Gordon
Nova chuck inserts
Ken
>Gordan,I have the midi that screws right on the headstock 1x8 of my Ricon,but when I got my Nova 1624 I got the super Nova 11 (I think). I am in Tampa right now and can't really remember which one,but the insert screws into the back of the chuck,then I just screw it on the headstock,but it does stay in the chuck.I got an extra one because I have a bunch of faceplates with 1x8 threads,that I want to use for other things.But anyway Tim said he could get me one,but never did,then I found these.I,m all confused now
Al Neighbors
>Hugh, unless I'm mistaken, an insert for the titan chuck is the same as the insert for the SN2s. I could be wrong. Call Teknatool's 800 number, and you can get to Tim Geist. He should be able to get you an insert for the Titan.
Gordon Seto
>Al,
You are correct. Titan uses the same insert.
Hugh Widdup
>thanks everyone I will check out the suggestions
