bevel heel problems
bevel heel problems
bevel heel problems
>Someone discussed making a 3/8" round skew the other day. Here is a photo showing one problem with a skew that thick. I was turning a very slight concave shape on this piece. The heel of the bevel is thick and quite sharp and will rub part of the shape. You can see that in this photo. The solution is to grind off the heel of the bevel so it is rounded. I do the same thing on my bowl gouges and spindle gouges to solve the same problem when turning bowl interiors. I actually prefer a thinner skew for this type of cut. The heel of the bevel doesn't rub as hard but rounding over that part of the bevel helps on this also.
Re: bevel heel problems
Bill Clark
>Excellent point John. I recently bought my second and third Thompson bowl gouges. Love the tools but I found I was getting burned marks and crushed fibers when making tight turns with the new tools. Then I woke up to the fact that the flutes on the Thompson tools were not as deep as my other gouges. I "back beveled" the gouges to remove some of the long bevel behind the cutting edge and it solved the problem. I should have remembered that Cindy Drozda does the same thing with her detail gouges to make small corners. Thanks for the reminder.
Dennis Yoder
>John, Try making a round skew from 1/4" stock and you will see the difference. I even have one made from a piece of 1/8" HSS rod inserted into a 1/4" rod for strength. It will get into places on finials like no other. Dennis Y
>Dennis I have a 1/4", 5/16 and 3/8 round. Only the 3/8 gives me trouble. It's hard to get into tight areas because it's too thick and then it does this shoulder rubbing thing which I have now eliminated.
My favorite mini skew is a 3/8" spade or paddle bit that has a 1/4" shank. I cut an angle on the flat part and sharpened it like a skew. It has a longer cutting edge than the 1/4" skew but handles pretty much the same.
GalenV in Iowa
>John Lucas
You have mentioned more than a few times about your skew made from a 3/8" spade bit. Can you show a picture of it? How much of the of the 1/4" shaft hangs out the handle and did you grind just enough of the end to get past the original ground end.
I have at least 3 maybe 4 old 3/8" spade bits that are no good for drilling so it would give one new life as a turning tool.
Beside I still need to practice with a skew of any type!
Thanks
Galen
3/8" spade bit skew
>Here is my spade bit skew. My bit had a hole in it so I cut the angle just below the hole. As you can see I've used up the 3/ marks but this skew has been used a lot and sharpened often with the diamond hones.
