lathe speed and wood type
>I was turning some olive wood tonight and thought I would play with faster speeds. This wood is quite hard but cuts very cleanly if you let the tool cut at the proper speed. Speeding the wood up helps in this case. It lets you move the tools at a more moderate pace which not only helps the shape but lets you move the tool at a pace that cuts very clean. Of course what I consider fast and what others consider fast is different. I was using the powermatic on the low speed setting and turned all the way up. I didn't look up the speed but believe it was below 1500 rpm.
I hope you can see it in the photo but this is straight off the tools. I used the Thompson skew and Detail gouge sharpened on a 100 grit wheel. The wood is almost polished. 400 grit actually dulled it but I had 1 tiny area that required 220 to get rid of some vibration marks. 600 grit brought it back to what it was straight off the tools. Nice wood.
