>I'm curious about using 2 sided tape for attaching turnings to faceplates, either metal or homemade wooden ones. I want to turn a few 3/8 to 3/4" thick discs, 2-8" in diameter, but am not sure how best to attach them. I don't want holes in them, either from screws or from screwchucks. Do you use tape? Pros and cons?
>This from my article on adhesives here on Wood Central
Carpet Tape
These adhesive tapes can be very effective for attaching a piece of wood to a waste-block of a faceplate when we remember that it has good shear strength, very poor tensile strength, and that it will creep and come apart over time when a load is applied. This means that we should not use it for holding a piece that is either heavy or long, and we probably shouldn't leave it hanging in the lathe for overnight.
I offer the following recommendations for using carpet tape.
- Use the fabric tape. This is usually a fiberglass. There are better tapes available, but those sold at Home Depot or Lowe's are fine for our use.
- Do not use the thin plastic film tape. It is totally useless.
Both surfaces should be reasonably flat and dry.
- Total coverage of the joint area is recommended for the first time usage. We will know how much less tape is needed for subsequent use after we have broken the joint apart.
- Both surfaces should be dry, smooth, reasonably flat, and CLEAN. -
- Clamp the pieces together for a few minutes after assembly. This can be as simple as holding them together between the head and tailstocks of the lathe or in a drill press. The adhesives on the tape will develop a stronger bond with time in a good joint.
- Turn the piece as quickly as possible after attaching it to the faceplate.
- Always try to break the joint with pressure. A cheap chef's knife makes a good prying tool.
- Squirt some Acetone into the joint if the bond cannot be broken with pressure. Allow it to soak for a few minutes, and I guarantee that the joint will come apart and that it will be a mess to clean up.
In spite of the clean-up problem, carpet tape is still the best way to hold some things in the lathe. I use it for holding plates, small platters, segmented rings and similar relatively flat turnings to a large MDF face plate. As an example, I make a lot of plates, both polychromatic and solid wood, that have a segmented rim. I attach a segmented ring to the MDF faceplate with 6 pieces of 1" square carpet tape, fit the plate into the ring, and then turn and finish sand the entire bottom before removing it. The thinness of the rim and the time involved for curing the other glue joints insures that I will have to soak the tape with Acetone to remove it without destroying the joints in the rim.
>Thank you, Russ, for that in-depth answer with reasons. Last week is the first time I tried the double-faced carpet tape and you just answered my questions, too.
>I've used DS tape for a long time. Along the way I've learned a few things about it. Carpet tape is okay for very small things. My preference is Permacel cloth tape. CS carries it. When I made a lot of platters a long time ago I used tape and it worked well. I now use it for small things such as collars, lids etc.
If used correctly it takes a surprisingly small amount of tape. Both surfaces must be flat and true where the tape will be applied. It must be clamped for a minute or so.
I won't work on wet wood. If the piece is at all heavy, don't leave it on the lathe overnight. It might be on the floor in the morning.
Removing the piece from the faceplate can be very simple. No messy solvents. I use a disc about a half inch thick and just a little smaller in dia. than the inside of the faceplate. Just remove the piece from the lathe, insert the disc into the threaded portion of the faceplate, install it on the lathe, then slowly thread the faceplate onto the spindle. The disc easily pushes the piece off the faceplate. No fuss, no mess.
>You know the wire you made with two handles to burn a ring in a piece. Just do the same thing but with thinner wire ( I use a high E string from my guitar) Turn the lathe off. Insert the wire where the tape is and sort of saw back and forth until you almost have it off. Then put both handles in one hand and grab the piece and pull the handles down. It will slide right through the tape.
>A friend of mine uses two-sided tape to turn large bowls. He puts a layer on the faceplate, then another layer on the wood, burnishing each firmly before removing the backing. Then sticks the two together. He has never had a large chunk of wood or bowl come off.
He uses good quality tape - Woodcrafts sells it. One layer should work fine for smaller things.
I like John Lucas' idea of using wire for removal.
>If you read Max Krimmel's articles about turning alabaster you will find that he uses Permacel double faced tape (available from Craft Supplies). If it holds alabaster I'm sure it will hold wood just as well. Just a suggestion....
