Reusing caked Anchorseal
Gary Evans Tallassee, TN
>Hi all,
I found a way to use the thickened layers of dried Anchorseal that you get inside a plastic container. I use a red coffee container with the little cast-in handle like my buddy JKJ had suggested.
Two days ago I started turning an open, green cedar bowl for some friends to pay them back for the tree they gave me. The first blank was really pretty, but I managed to demolish it when I was about half way into hollowing the inside. Should have been around 7" diameter and 7 or 8" high. Now that one will end up around 7x4.
The second blank has behaved quite well, though I've not quite finished turning the outside. When I had to stop turning the other evening, I needed something to seal the outside of the blank.It was still quite green and I was looking at several days before I could get back to it.
I had recently cleaned out the inside of my Anchorseal container so I thought about rubbing some on with the lathe turning. It gobbed up pretty good, but I'm taking off at least another 1/8", so it should all disappear.
I'll report if there are any ill effects.
Gary
Re: Reusing caked Anchorseal
>Since anchorseal is just wax, water, and surfactant to keep the wax in suspension, any way you apply it should work. I suspect that caked anchorseal could be re-emulsified with water and agitation, perhaps with the help of a little heat, but I haven't tried it.
Bring those logs to saw and I'll fill up your container!
