Wolverine setup
Don Orr
>I am finally getting ready to replace my old home made sliding rest for sharpening gouges. I have a Oneway Wolverine grinding jig that I want to set up on my Craftsman 8" grinder. The directions show that the platform on which this all sits should be 6 1/4" below the center of the wheel. The center of my wheel is 7" above the platform now. As it is I will have to cut off part of the chute in the back of the grinder to get the jig base under the grinder. I don't see how I can obtain the 6 1/4" height described in the directions. (Yes I read directions). If I put a riser block under the jig base it will be very close to the wheel and the shroud will probably be in the way. Does any of this really matter or can I just mount the jig base under the wheel at whatever height I already have and call it good. What have you all done ?
