Re: Waterlox
Greg Haugen
>Bill if you search the archives for "waterlox" you'll get alot of info as well. Here are my answers for your questions.
1. How applied-wiped on with a paper towel or soft cloth
2. How many applications- minimum of 2 for bubinga-higher resin/oil content in the wood, most species 3-4. I don't like the ultra shine of some finishes and you can get Waterloxz as shiny as you want-just keep coating.
3. Time between applications-usually over night at least-longer for the first coat since there's more absorbed and applied usually. If they're applied too quickly the coats don't have time to "build up" they just become one thick coat in the wood.
4. Time left on before wiping off-5-10 minutes, 15-20 max. I'll also wipe off with the same cloth I applied it with. It wipes off the excess and "levels" off everything else.
5. Buffing or other steps after last coat- Usually nothing-although after reading Ellsworth's book, highly recommend it no matter what you turn, I do buff now lightly with tripoli followed by a "bare" buff. Incredible feel and surface.
6. Other tips, advice re: Waterlox use- there are many methods in prolonging the "gel" effect of waterlox. Experiment to find one that works for you. I've used marbles sometimes and also decant it into smaller containers. There are several methods in the archives.
Hope that helps,
Greg H.
