How to adjust pulley on the motor shaft?
Henry (Raleigh, NC)
>I am a new turner and bought a used Nova 3000 (I think that is the model). The drive pulley assembly is a single piece with several size pulleys. The position of this assembly seems have gradually shifted on the motor shaft, away from the motor. There is a key and keyway on the shaft, with a set screw.
I have loosened the set screw, wanting to shift the pulley assembly in towards the motor. It does not budge. While I could start to use force here, I thought I would ask advice first.
How do I shift the position of this pulley assembly when it seems stuck?
Henry
Re: How to adjust pulley on the motor shaft?
paul waddle
>1rst,take the set screw completely out,sometimes there's two,one underneath. Secondly,look 90* to see if there is another set screw. Lastly,there is probably a burr that is preventing the pulley from sliding. Ascertain which direction gets pulley off key quickest. Drive the pulley at the hub(not 0n the diameter) until you can get key/pulley off. Deburr with a file,grease shaft a bit and put pulley, and key back on. Align with driven pulley,tighten setscrew. Run and recheck alignment.You may need metric allen key unsure. pw
Mike Stafford
Mike Stafford
>Henry, it might be best to remove the motor assembly from the lathe. As I recall there are only two bolts to deal with and make the pulley adjustments on the motor shaft when it is easier to access. It is easier to have some help when you are removing and reinstalling the motor.
It is also very important to make sure that the drive pulley and the spindle pulley are in alignment so that the belt is not twisted under load.
Have you any idea why the drive pulley shifted?
Re: How to adjust pulley on the motor shaft? *LINK*
GalenV in Iowa
>If you do not have a manual I suggest you download one so you have for reference.
How have you determined the pully moved. Are there marks on the shaft or are the pulleys not in alignment? The pulley would self align if the motor shaft was true to the spindle shaft. It will walk if not true to the spindle shaft. If pulley is stuck seems odd it walked.
I agree if the pulley is stuck do to a burr it is safer to remove the motor and as noted only drive from the hub of the pulley.
I hope nobody run the belt so tight the key started to shear from a catch or jam and that would make pulley removable a lot tougher.
Galen
http://www.teknatool.com/products/Lathes/3000/downloads/Nova3000manual.pdf
>I find the best way to get rid of the burr is to use a drill. Select a drill bit that just fits inside the threads. then carefully run the drill down until it hits the shaft. Run the drill slow and just remove a little. It might take a try or two but that would be better than wallowing out the threads if you use a fast speed.
If I remember correctly that was the exact problems with my Nova 3000. The pulley on the headstock would slip all the time and require a periodic tightening. I had to use the technique above to remove it but you really only need to knock it back into position. Use a block of wood and tap it lightly until you get it aligned with the pulley on the motor shaft. Of course you can also to pulley on the motor shaft or it might take adjusting them both.
Henry (Raleigh, NC)
>I am still somewhat confused here - but I will try to answer the questions or concerns raised.
Paul:
- I do not think that there are 2 nested set screws - although I have not pulled out the first one completely.
- I am not certain where the burr might be - I suppose you mean a burr on the shaft or the inside diameter (mating surface) on the pulley assembly. I guess until I can get the pulley to move on the shaft, I really don't know whether there is a burr.
Mike:
- I do have the motor off already. That was relatively straight forward.
- I could not determine why the pulleys may have shifted - especially since they seem quite locked into position on the shaft right now.
Galen:
- I do have the manual - thanks for the link though. It suggests something like 'sliding the pulley onto the motor shaft and tightening the set screw loosely.' I can't move the pulley on the shaft - hence my question.
John:
- I did not check the headstock pulleys - I presume they did not move. I think it is the motor drive pulleys that have moved because
1. the end of the pulley assembly is rubbing on the inside of the case.
2. the separation between the motor and the pulley is suggested at 1/2", and it is greater than 1"
3. I can't align the two sets of pulleys, they are about one belt width 'off'
I presume that the description of "driving the pulley at the hub and not the diameter" means to provide persuasion/force closest to the shaft.
I will try some penetrating oil to see if that helps
I gather from the collective description that the pulley should move easily on the shaft? That is certainly not the case right now.
Thanks for the quick responses and ideas so far - I will continue to work on it. The anticipated snow this evening may provide some relief from work tomorrow!
>Sorry about that I should have explained that the burr we are talking about is caused by the setscrew. It puts a dimple or crater on the shaft and makes it very hard to move the pulley. The dimple is usually smaller than the drill bit that will fit down the hole so the drill removes the high spot of the crater edges or we call it a burr.
Sometimes you can make a tapered wooden wedge the drive the pulley off. Make it a gradual taper because you don't want to damage the outer edge of the pulley. Usually once you get the pulley to move it will come off fairly easily. File down the burr so it will go back on easily.
It does have a key and it could have been damaged but not usually. They are usually harder than the pulley.
Mike Stafford
Mike Stafford
>I would imagine that dust and grit have accumulated in the key way and under the pulley making it fast on the shaft.
The pulleys are a reasonably tight fit on the shaft but once the set screw is loosened they should slide with moderate force. My bet is that grit and grime have monkeyed up the works.
Mike Stafford
Mike Stafford
>I thought the set screw was tightened down against the key. That is why the pulley has traditionally worked itself loose. The key slot and the key slot in the pulley worked the set screw loose, I thought....
GalenV in Iowa
>If the pulley is aluminum or a zinc casting it may have seized to the shaft and/or key. Fine dust as noted too may make it hard to remove. You might try using a drift pin down through the set screw hole and giving it a rap. This may jar the key enough to break the hold.
If the pulleys are off one belt width it is hard to imagine but did the last owner do that intentionally to change the speed ranges?
The step pulleys MAY have allowed one belt to be used but just a different length. I have not looked at my Jet to see if the pulley ratios would allow that.
Galen
Jim Pugh, Elyria, OH
>Suggest you contact Woodcraft in Parkersburg as they were the original sellers of this machine. Also, be careful attempting to move the pulley. A friend and I managed to bend the motor shaft while putting the pulley in place because it was so tight. Actually, we bent the shaft while trying to wedge the pulley back off so we could file the shaft a bit.
you could be right
>I haven't had that lathe for 3 years now so my memory isn't that good.
Mike Jones, Redding, CA
>Henry, Welcome to our group! From the previous posts and your response, it appears that you are proceeding perfectly. I would question if the pulley moved away from the motor before the lathe came into your possesion or after. If before, the problem may have been created by the previous owner. (maybe a clue!)
With the pulley-to-motor gap being in excess of an inch, you should be able to see the key in it's keyway, as both extend from the end of the motor shaft to about a half inch out from the motor case. If looking there, you see a keyWAY and not a key, I'll guess that someone tried to install the wrong key...the pulley body hanging up part way home.
At any rate it'll be best to remove the pulley, and John Lucas's method with a wedge to encourage it a bit, (I think that I would go with two wedges, one on either side of the shaft and tap them in with alternating hammer strikes) will serve the purpose and expose the source of your problem.
Come back and tell us how you solved it!
don lewonczyk
>Tim Geist is a machinest and the repair center for Nova lathes in W.V. he can tell you how to proceed with your problem. Alot of good suggestions from the group and I'm sure something would work. Not a lathe pulley but I had a motor with a pulley that was stuck on the shaft because the key was to small and the pulley moved out of the keyway and on top of the key and the only way I could get it off was to lock the motor shaft with vise grips and a piece of leather to protect the shaft and then rotated(wiggled( the pulley with a strap wrench until the shaft keyway and pulley keyway lined up and with a little lub and gentle prying it came loose. May not be your problem but when you buy used equipment expect anything. DonL
Nova lathe - Tim Geist?
Henry (Raleigh NC)
>OK Don. Since I do not frequent this board - is Tim going to see this thread and respond? How do you suggest that I obtain Tim's advice.
I have not yet tried any of the suggestions - the snow here in Raleigh gave me a 2 hour reprieve from work, but I just read and drank coffee. Oh to have that much time every morning.
Henry
Re: Use a socket wrench
Bill Turpin in WNC mountains
>Use a socket that matches the hub diameter and a light hammer (applied to the square drive end) to knock the pulley back on. The force will be uniformally spread around the hub. This will take care of any unegual forces that might be causing binding. If you ever get it off, use a file to clean up the key, key corners, key slots in the pulley and shaft. It should be an easy slip-fit before re-installing. A tapered tie-rod end fork-puller can be used to force the pulley off. Do not use one to push on the pulley flanges. Push only on the hub.
Bill in snowy WNC mountains...10 inches, first time in many years
Pulley adjusted on the motor shaft
Henry (Raleigh NC)
>All: Thanks for all the input on how to adjust the position of the pulley stack on motor shaft.
I removed the motor from the lathe and suspended the motor inside a metal pail, supporting it by the lathe mounting plate; this mounting plate was fixed to the motor case and located between the motor and the pulley. I had sprayed some penetrating oil on the shaft in around the key and let it sit for a while. I then forced long thin wedges between the pulley and the mounting plate to gradual shift the pulley assembly off the shaft. It held tight to the last moment.
I then cleaned up key and keyway of accumulated grit and reassembled the pieces. With clean and burr free pieces I now have a 'feel' for how easily this piece should shift along that shaft.
It works fine - as long as I remember to tighten the set screw once the motor is mounted and pulleys aligned.
Henry
Re: Pulley adjusted on the motor shaft
>Two thumbs up for you, Henry!!
