Buffer speed
Buffer speed
Buffer speed
Ed Wujciak
>I recently inherited a near-new 6" Ryobi grinder and, since I don't really need a grinder, I thought I might turn it into a buffer. Then I noticed it runs at 3600 rpm and wondered whether that speed would work. As you can tell, I don't know much about buffing as yet. I'd appreciate some advice and thanks.
Re: Buffer speed
Re: Buffer speed
Cyril Griesbach
>It should be fine if you use a light touch and the wheels are reasonably balanced.
Re: Buffer speed
Steven Antonucci
I use my lathe
steve antonucci
>I just make an arbor that can be gripped with a chuck, and I have a variable speed buffing wheel...
Steve
Re: Buffer speed
Re: Buffer speed
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>It will certainly work. The drawback to so much speed is that sooner or later (as has happened to me) the buffing wheel will grab a fine piece, throw it out of your hands at lightening speed, and smash it on the floor of your shop! The trick is to never let the wheel catch on a flat place, like the bottom of a vessel. Always make sure the wheel is on the "downward" slope, if you see what I mean.
Re: Buffer speed
Re: Buffer speed
Jim Terry
>If you use 4 inch buffing wheels the surface speed is reduced. I have a Craftsman buffer that runs at 3600 and it works ok with 4 inch wheels.
Re: Buffer speed
Re: Buffer speed
Ed Wujciak
>Thanks to all of you who responded. It will help me decide how to proceed.
