>Don't you just love some of those operating instructions?
I bought a Brush Grubber Xtreme (photo) to pull up brush and small trees with the tractor. Much quicker than wrapping a chain around the tree, it has steel teeth on 3" grip pads to grap up to a 5" trunk, designed so the more the force, the tighter it grips. This thing is SERIOUSLY built: 1"x1.5" steel arms, etc., probably weighs close to 40 lbs.
I was amazed this line in the instructions:
"The Brush Grubber Xtreme is not to be used on people or pets."
Why would they even PUT something like that in the instructions???! Take a reluctant rhino for a walk? Haul off that obnoxious boy that's been hanging around the daughter?"
>John: That goes along with the disfiguring messages posted all over the upholstery of your automobile. They forgot to tell us not to stick our tongue in the cigarette lighter socket.
>I think you'd be happy with it if you have a tractor or pull with a 4wd truck. They claim you can use it with a 4-wheeler but a 4-wheeler is just not heavy or powerful enough to pull larger than a smaller plant, say 2" or so in diameter (depending on the type, root system, soil.) This is advertised with a 5" diameter capacity, but I haven't tried to pull one that large.
If I planned to use it with a 4-wheeler, I'd probably buy one of the two smaller versions, which are quite a bit cheaper as well - $60 or $80 instead of $120. The smaller versions don't have the handles but you could easily weld some on if needed.
I clear most brush and trees by scraping or digging with the tractor bucket, but a big advantage of this thing is it doesn't disturb the ground. I even remove most trees with the tractor - it's surprising how large a tree can be pushed over, especially if you dig a bit around the roots. Sure saves a lot of work digging up stumps.
BTW, my backhoe and I dug up a cherry stump yesterday that probably weighed close to 2000 lbs, judging from the way it just laughed when I tried to pick it up with the front end loader. I wonder if there is any good turning wood in there. Anyone ever turn cherry root?
>But I think you'll need to pressure wash it for a bit. I have a 30" root ball at my MIL's house that I can't figure out how to process. Dirt and rocks everywhere, too big to move...
I've hacked a couple of little bits off of it, and I go back every so often...
>Where I work, once in a great while (three times in twenty years that I know of) someone will put an absolutely outrageous statement into a report just to see if anyone ever reads the report. If the report gets closed and filed, they know that their effort was just a paperwork shuffle. It makes it hard to be motivated to do good work when you know that no one ever reads it.
>Steve, I power washed the root ball of my maple tree after the hurricane dumped it over. Visualize moving the dirt directly from the stump to your person at about a thousand miles and hour. In the middle of the process, you couldn't tell which was the stump and which was me, except I had the magic wand. Someone offered me a walnut stump and I declined.
Do you have a toothbar on your tractor bucket? I find it is really difficult (and messy!) to dig around roots without one. Pushing over trees is a real rush! Pulling on a very big tree or bush sounds like a good way to whack your tractor...is there a warning about pulling a tree over onto yourself in the brush grubber instructions?
I don't have a toothbar. I use a 12" bucket on my backhoe which works pretty well but a narrower bucket would be better. This stump was challenging since the tree was about 30" from a 2" gas line buried about 18" deep. I couldn't risk pulling the line out with a root so I did a lot of manual work with a bar and other tools. The axe and old chainsaw chain got it loose enough where I could work it out with the backhoe. Cutting roots sure is rough on a chain! Some of the roots were 10"-12" in diameter.
The Brush Grabber instructions are very clear about the danger of whacking yourself and equipment with a tree. Step 1: cut the trunk off 3-4' from the ground. But you know someone will pull one over on himself.
I spent the day digging and reburying rocks. While leveling a spot, a couple of rocks protruded about 6" and I couldn't budge 'em. Dug then up with the backhoe and pulled out two rocks about 5'x5'x3' each. What to do with them? I dug bigger holes and buried them in an area with fill - I'm sure they will help stabilize the bank.
I've pressure-washed roots before and I know exactly what you mean! Anyone who tries this - be sure to wear a rain suit and A FULL FACE SHIELD.
I have a couple of walnut root balls I may get around to one day. I find it easier to pry out most of the dirt with a steel bar first, then pick up the root ball with the tractor and slam it into the ground a few times to knock out most of the remaining dirt. You still get embedded rocks which are fun when sawing.
Come to think of it, a reciprocating chisel on the big industrial Bosch SDS hammer drill would probably make all this a lot easier.
>They make Preparation H and Chap Stick locally. I did a Home Inspection for one of the guys running the machines. According to him about twelve people make almost all of both. They make them on the same machines. I said, "Hope you don't get them mixed up." His answer was, it didn't really matter they were pretty much the same thing.
>I'd kill to have a boulder that size! I love rocks...I guess because we don't have any here, they are a novelty for me. I am sure there are tons of kids here who don't even know what a rock is because they have never seen one! LOL
