Last week our local turning club was treated to a demo by Peter Bloch, THE lampshade guy, and decided to "give it a go". In fact, Peter gave me the blank he had started hollowing on, with about 3" thinned down, but I had to cut off the part he had done and re-round the entire piece so I could support the heavy blank with my tailstock. Since I don't have a 1-1/4 faceplate bigger than the 4" one that came with the lathe, I needed the extra support.
This first pic is the lampshade on the lathe with a drop light shining through it, almost finished, with the tailstock removed for the final steps...
>Here's what I ended up with after cutting off about 1.5" to get rid of the cracks. I made a thin, end-grain bowl from the stub left on the faceplate, and held it in its approximate relation to the lampshade with an inverted beer glass.
I'll probably still use this somehow, but now need to figure out how to finish it off. I'll probably turn some sort of thin top element, and join the two translucent pieces with an opaque ring of sorts that will attach to the lamp harp...
I learned 4 important lessons here:
1. With a gentle touch, I can turn a thin lampshade, and so, I bet, could you.
2. Thin end grain is very weak, so I now know to sharpen more often and use less force.
3. This shade is too thin! When I compared it to the ring turned by the master himself, mine was maybe twice as thin. No need to go that thin, and probably a few dozen reasons not to.
4. Sure was good to get out in the cold and turn something! A little too much winter here, so I really appreciated a warm evening in the 20's...
I had a lot of fun, and will try it again when I get another big chunk of Quaking Aspen. This was a medium/large tree -- about 22" diameter. Peter started rough turning a different one that was 27" diameter at the butt -- a pretty big Aspen! To see what's possible, check out Peter Bloch's web site -- he makes his living doing this, so he's figured out all the things we beginners stumble on!
>How are these protected from the heat of a light bulb?
Seems like it would eventually turn into a pile of crisp potatoe chips.
Guess I have seen birch bark lampshades and always thought FIRE.
When I see turners using a light to gauge thin turnings I wonder if in short order they would warp a green thin turning. Guess a GE cool light is required :>)
I'm a long way off from trying to turn a thin lamp shade or hat but assume I will do it someday just to see if I can.
Thanks for your questions. This shade may be a little bigger than it looks. It was about 16" diameter when fresh-turned, and has now dried and shrunk to ~15". Thus, when finished and assembled with support structures, they are suspended far enough away from the bulb that heat is no issue. While the heat from 60 - 75 watt incandescent bulbs would be no problem, I use only CFL's which use 4 - 5 times less electricity, and produce far less heat.
When using a light to gauge thickness, the wood is still quite wet, which also makes it more translucent. The wood was also stored outside in my barn in the cold for the past week, so it was frozen also. The photo of the salvaged shade placed over another lampshade shows much-reduced light transmission, since the wood is now dry, but it will transmit a lot of light once I soak in some Urethane Oil.
They are much tougher and more flexible than they look. Since these are end grain turnings centered directly on the pith,they tend to shrink symmetrically, and tend to stay round.
I hope to try another soon, and will try to post photos of the attempt. I can assure you, I have a lot to learn about this sort of turning.
>Very, very nice Brad, I would bet the rich sportsmen would love one or two for their cabins or even us middle class. I like things like that are made by us ordinary people. Thanks for sharing, DonL
>Wood is such an amazing material - and we usually only get to see it's opaque outside surfaces. Yet it can be cut/turned thin enough to be translucent - to reveal far more - as your piece nicely illustrates.
Enjoy the fruit of your labor (though I bet it was fun as hell to make).
I'll bet it was fun spending a day with Peter. I saw him demo at one of the Totally turning Symposiums and spent some time yacking with him at Sunapee a couple years ago. He was also the critiquer at the NH woodturners meeting you invited me to when your dad was still alive. He is a nice guy and produces some really nice work. I still quote his version of "logging on" in the morning.
I can imagine it was fun doing one of his lampshades. Too bad you got the cracks. Do you think that the wood was getting a little too hot from the scraper, or just that you were over stressing the wood from the pressure? I have a few larger aspens in the woods that surround our fields that I would not mind taking down as I think they are nearing the limits of their life. Maybe not as big as some that Peter turns, but big enough. Did you find out when he fells the trees? I took a paper birch down last summer with the intention of using the larger part of the wood for turning. I found that the wood spalted/stained a really unsightly black/gray in smudges. Not pretty spalting. I have since found out that this is not unusual with wood harvested in the summer. Taking a birch down in the winter when the sap is down seems to alleviate the problem, so I have been told. I haven't tried taking one down this winter because the snow is just too deep for me to get my tractor out to retrieve it. I wonder if the same may be true for Aspen. I turned aspen when I lived in CO, but limited it to just burls and didn't really try any larger trees. They are related species, and I would think that aspen may be even more problematic due to it's higher water content and lower sp. gravity.
If you think that taking one down in summer might work, let me know and we can go harvest one after mud season. I would be willing to share the wood with others in your group if they are interested.
You're a tougher turner than I am. I have been hanging out in the heated shop but mostly doing some carving on a hollow form that will not be done for a while (no hints) and building some built-in library shelves for our den. I don't think I would be out turning in the weather we've had lately.
I'd love to play woodsman on an Aspen or two -- I'll be in touch when spring gets things dried up a bit.
I don't know when Peter's trees are cut, but he tries to let them spalt for 6 - 18 months lying horizontally in 10 - 12' lengths on a crib of 4 x 4's. He often has 6 - 10 logs laying around, and cuts chunks as needed and as they age to desired spalting. One issue is that the lower side of the logs ends up heavier than the upper parts from laying around, so high-speed balance is an issue.
In my experience, a Paper Birch that's laying on the ground is best described as "compost in a tube" -- they sure go fast, and seem to stew in their juices with that waterproof wrapper.
The cracks seem to be from pushing too hard. It looked to me like I was starting to separate the growth rings, but only as I came around into more end grain than side grain. I want to get another teardrop scraper tip for the Stewart system, and swap freshly-sharpened cutters more often. I was trying to do this in a hurry so I could finish it on one session and get it done before my wife returned from her book group, so I was rushing too much. These have to be turned pretty quickly to keep the thin wood fresh and wet, but I should have sharpened more and pushed less.
I look forward to a shop visit and Aspen-butchering session this spring.
