Grex RO sander
Grex RO sander
Grex RO sander
>is anyone using this. What do you think of it. Is it a big improvement over power sanding with an electric drill or just another gadget.
I won't have my big compressor installed for several more months so I'm wondering if this will work on a smaller compressor. I know it will probably recycle often but if it's not too big of an air hog it might do for small bowls and platter for now. It says 8 cfm at 90 Psi which means I can only run it a few minutes if that's accurate.
Re: Grex RO sander
Re: Grex RO sander
Stuart Johnson
>John, I use the Grex RO and like it. I only had a cordless drill when I bought the ROS so I can't compare it to a regular drill. I have a 25 gallon compressor and it will cycle fairly often. I just keep on using it but as a passive sander until the compressor finish the cycle. An 80 gallon is on my wish list but not right at the top,
Re: Grex RO sander
Re: Grex RO sander
Ron McKinley
>I have a friend that uses it with an 80 gal. compressor. That's all he uses for sanding. I've used it a few times and just today was out looking at compressors! .......Ron
Re: Grex RO sander
Re: Grex RO sander
doug williams
>John I just got a new compressor last month, and I have the sander, I used it on bowl that's drying just messing around as the tank depleted its air supply, the regulater set at 90#, when it got down to about 45# it seemed to have more feathering,softer, touch than running wide open at 90#.Just my opinion, haven't used it that much. The compressor is a Dewalt 15 gal. my old one 20 gal. I had the guy plug it in at lowes, this other guy was grinding a key, it wasn't any louder than the key grinder. I think the decible was around 76 for the Dewalt, my shop is in the basement. Taking a chance on Dewalt's quality, and see how it turns out. Doug in Ohio
Re: Grex RO sander
Re: Grex RO sander
Bill McWhirter
>Got one. Really like it.
I also have the$19 Harbor Freight one. They seem to work equally well and use the same disc. The major difference is that the HF head is at 90 degrees to the handle, and the Grex is at around 75 degrees which is a bit more convenient. Don't know about durability.
I use it with Vince's blue discs and a soft interface pad most of the time. It does fine connected to 60 gal compressor.
It is great for sanding on the lathe and I frequently use it for the initial sanding on lacquered pieces. Two thumbs up.
Re: Grex RO sander
Thanks guys- I think I'll go for it.
>Since drills aren't designed for sanding I figure sooner or later my Dewalt drill will die. It's also kind of heavy. I want a one handed light weight sander and it looks like that will do it.
I have to run a new 220 line to my shop to handle enough current for the new compressor, my future purchase of a bigger dust collector and possibly an electric heater. That will be kind of expensive and be a chore to run so I'm putting it off for a little while. I'll try it with my current HF cheapie compressor and let everyone know how it runs.
Re: Grex RO sander
Re: Grex RO sander
Jennifer@Indy.USA
>John I love mine. I've been using it for several years now with a Porter Cable "6hp-25gal" compressor. It does cycle often. A biggie compressor would be a treat. It's a really nice RO sander.
Jen
Re: Grex RO sander
Random Orbit vs. Dual Action
Mike Jones, Redding, CA
>Can anybody comment on the effective difference between the DA and RO?
Re: Grex RO sander
Re: Grex RO sander
Lan Brady
>John,
I have one and use it often. I only run it about 35psi. I can use it with the lathe on or off, no swirl marks.
The compressor is 25 gallons and it last about 25 minutes without recycling.
Lan
Re: Grex RO sander
Re: Grex RO sander *LINK*
Juergen
>John, I would not do without a RO Sander. I have a Grex and it is a good piece of equipment although a bit overpriced. I also have the unit at the link below
Even though it doesn't say RO, it is. I've seen it as low as $19 on sale. I've had the HF unit for several years, used and abused it and it still works perfectly. The head angle of the HF unit is 90 degrees and the the Grex 105. I've not found the extra 15 degrees of much benefit.
If your compressor can't keep up with the air demand, just use it like a Sorby passive sander until the compressor catches up. It can also use a 3" sanding pad the shaft is 1/4"-20 pitch. To manage air add a small inline pressure valve close to the sander.
If I were to do it again I would purchase 2 of the HF unit and buy extra sanding disks adn a 3" backer pad.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93629
HF RO Sander Link
Re: Grex RO sander
Jeff Morneault in northern Maine
>Is the hf sander random orbit? I can't see that mentioned anywhere on the site or in the manual. I'd definately try it out at that price.
Re: Grex RO sander
Re: Grex RO sander
>Oops, sorry Juergen, missed the part in your post about the hf being random orbit. Ah well, time to get more coffee.
Jeff
Re: Grex RO sander
Re: Grex RO sander
don lewonczyk
>John, I have the sander and the drill, the sander works good on the other hand the drill is a piece of work. When you pull the trigger the chuck runs out about 1/8" or better forward an is noisy so I pulled the cover back and found a geared sphere ( the driver) running the chuck. I should have returned it but I guess I was lazy and forgot about it. There is no substance to it. DonL
