Vacuum Pump advice *LINK*
Rick Davenport
>Since I like to do so many natural edge bowls,,,,,,,
Any updated sources for a vacuum pump?
Here's a link to a pump that may work.
Any thoughts?
Thanks,
R
http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=30479
Re: Vacuum Pump advice *LINK*
Greg Haugen
>Rick,
I know some have used Surplus Center. There's a link to their site below. Gast's are around $50, used. You could buy four of those for the price of the other one. Also check on Ebay.
Greg H.
Surplus Center Vacuum Pumps
Greg Haugen
>Rick,
Also, here's a link to Harbor Freight's page of vacuum pumps. They have quite a few.
Greg H.
HF's Vacuum Pumps
Another Thought......
>Locally there is a company that remodels dentist's offices. They are a good source for used air compressors, vacuum pumps, and Dentist lights. I don't know their name, but it think I could drive to the location if I wanted to. I don't know how to tell you to find such a place where you are, but you might check around. I also don't know how good their prices are either.
(This was a lot of typing for a guy who knew so little.)
Dick Hines
Re: Another Thought......
Dick Hines
>Barry, why don't you drive there and let me know where they are. Then I could drive there and get a pump.
Hope this was not another Senior Moment.
Carol - now back in Dubuque, IA
>There are three kinds of Vacuum pumps; venturi type using YOUR air compressor [assuming it is big enough] vane type [most popular] and the oil filled] the most expensive. I have the Surplus Center vane type, the Harbor Freight venturi type and an oil filled. The oil filled is the quietest. The venturi is the least reliable and the most expensive to run, [continuous running of the compressor]. I made a vacuum pump cart when I was teaching the vacuum clamping class, so it got the vane type. Didn't have the oil filled then.
Like so many tools asked about on the forums, it depends on its intended use.
For vacuum clamping on the lathe, its a toss up for me between the oil filled and vane. The venturi could proved the most excitement though. The first instant there is no air, we have launch, Houston.
Lessee..... Kevlar chest (and other vital body parts) protector, full face Lexan shield, ear protection...OK, ready for final countdown, over?
For my part, just so I don't have to rebuild the vacuum cart, I'll use the oil filled for the lathe system. heheheh
Walter Ahlgrim
>The thing I don�t like about my oil pump is the fine mist of oil in the air, it looks like smoke. The dry piston pumps are good if you find a bigger one.
Walta
>Here ya go, Walt.
Put it on the exhaust side.
HF oil/water separator
Carole Valentine
>And while you are there, Dick, you could get me a light!
Doug Turner
>I bought a used Gast diaphragm vacuum pump with a 2cfm capacity. I can pull over 28 inches of vacuum using the kit in Craft supplies USA, and it is very quiet. I have the motor mounter on a shelf at head height and it is not distracting at all. I have a GAST carbon vane vacuum pump and it is much louder and vibrates more.
Rick Davenport
>Thanks all,
I think I'm leaning toward the Surplus Center pump.
From what I hear, once you've gone vacuum, you never go back.
R
Alex Stewart
>Why don't you go to www.yellowjacket.com Their web page and you will get the greatest selection of vac pumps. We sell them here in Europe and UK
The company is based in Bloomington Mn. I can certainly vouch for their ability to pull a vacuum I have had them down to 12/15 microns.
Company name is Ritchie Engineering.
Mike Nelson
>Good choice Rick, I would buy the new one for thirty bucks more if it were me. Also stick it behind a storage or closet wall if you have one near your lathe
