Return to the Gavel..
Randy G
>Hey everyone, there was a thread on here a while back about a gavel. Had a couple questions in regards as I was trying to make one for my mother.
Not so much in regards to the design, but what are the basic diameters and any opinions on why you like yours those diameters? example - Head is 3" by 3 1/2" and Handle is 1" by 8"???
Next would be why the threaded Handle attachment. Seems like everyone threads the handle onto the head. Is this for fun? strength? or something else I'm missing?
Re: Return to the Gavel..
Pete in Holland, MI
>Kinda depends on the size of room you are trying to get control of. Made a couple in years past that were 2 to 2 1/4" diameter by 3" long or so. Handle 8-9". Faces should be slightly convex with no sharp corners to dent/chip away. Have simply drilled thru the head and fitted the handle all the way thru with a wedge more for looks. Tenon into the head should not be too small. Mine were about 1/2".
Make sure to make an "anvil" to pound on with rubber feet/pad, else the furniture owner will come after you!
>I measured some of mine - they are about 2" to 2-1/4" by about 3-1/4" to 3-1/2" long. The unthreaded part of the handle is about 8" long by a little more than 1" in the widest places. I'm not too concerned about the exact dimensions since I don't make matching sets of these. I use these dimensions since I like the way it looks and feels.
I fasten the handle with threads because it's strong and I'm afraid a glued joint will eventually loosen, perhaps with the humidity. It's also fun to unthread the handle while showing the gavel - people seem to be impressed by that for some reason!
Re: Return to the Gavel.. *LINK*
>Randy,
I forgot if this was mentioned before, but Larry Hancock talks about gavel sizes a bit in his tutorial. (link)
Hancock's gavel tutorial
