>I just came into a large amount of American yellowwood (Cladrastis kentukea, Gopherwood) Anyone ever turned this? It seems to have a tendency to check, and ring shake is a problem with at least 1 of the logs.
Any advice or experience is appreciated. The picture shows about half of my haul. I shared the rest of the load with turning club members.
Before anyone gets up in arms, I know that Yellowwood is endangered in much of its native range. This tree was an ornamental and was threating several units in a condo complex so the determination was made to cut it down, which we did.
>I haven't turned any, but wow, I can imagine that some of it will be both spectacular and unusual. There are some amazing boxes hiding in some of those pieces with the dark figure!
>Unfortunately, much of the wood with the dark graining separated along those lines while we were cutting it up. I thing a lot of CA will be needed to keep it together.
>I've turned a fair amount over the years. My experience is to turn it wet and thin, and let it warp. The stuff I had was very hard to dry without a lot of cracking, but the bowls and vessels I turned thin held up well. There was some warping of course, but it wasn't too bad. I don't know about your tree, but the two trees I got both had lots of curly wood in them. Good luck with it!
>I have recently turned some pieces of yellowwood, however the species I had was Cladrastis lutea - this tree was also grown as an ornamental on the Iowa State University campus that had to come down due to excessive heart rot near the crown. The pieces were not in the disposal log pile for more than a day or two before we had scavenged all useful parts of the tree!
In my experience, the wood turns very well, and finishes nicely. It's fairly dense, and not too bad on tool edges. The figure can be variable, with respect to grain pattern and color, and the sapwood (in my opinion) should be turned away - seems to be quite a different density (at least on the one tree specimen I have worked with). I turned my pieces green, so I have no idea how it behaves on the lathe if originally turned dry. Checking informtion on it before turning, I could not find any data about this wood's toxicity or health concerns. Since it's a legume, I approached it cautiously, regarding skin exposure and dust. I had no problems, but (as many people would agree) I have a pretty thick skin! Take usual precautions, and treat it like a rosewood until you are convinced you won't be bothered by its shavings or dust.
I also have no idea how long the vibrant yellow color lasts, or if it fades to a lesser intensity of color as many highly colored woods do.
Good catch - you will find that the wood is quite desirable for turning!
>,...fades fairly rapidly to gray when exposed to light. I have turned mostly what is know here as KY Yellowwood, and don't know if it is the same species as your stash.
>I have turned a bucketload of pens from Yellowwood .. and they each looked rather snazzy .. Sadly, I just this last Friday missed an entire Yellowwood tree. It was cut cracked from ice/wind and was cut down, chopped up, and either ground up in a chipper, or is someone's firewood. Bummer ..
And everyone who said it checks quickly, they did not lie! haha
>Beautiful turning wood; hard and dense. Has very fine growth rigs when grown as an ornamental this far north (VT/NH), well out of its native range. The pieces I've used were more colorfast than Osage Orange or Mulberry. Sapwood can have interesting lines and color from both spalting and bugs.
Nice haul -- enjoy it, as this is a pretty rare tree.
