Help wanted
Richard Jones
>OK, trying to do some peppermills, here's the problem: After drilling and turning the tenon on the cap, cap and base seem to turn on a different axis, i.e., they don't line up true when they are turned. So, the answer would be that either the tenon is not in the center of the cap or the hole in the base is not in the center, or something else that I'm not seeing. I found center of each part with the point of the skew prior to drilling. Hole in base is drilled from each end, not all the way through from one end.
I believe the lathe is set up properly, spec., spur center and cone center line up. Holes seem not to be drilled improperly, i.e., no vibration, no visual signal that they're off, etc. All parts seem to be running true, even after reversing. Difference is slight, but there nonetheless. And, this doesn't happen on every mill.
Can't figure this one out and it sure bugs me.............
Thanks for the help.
Rich
